MBfreak
MEMBER EMERITUS
We are working with a differential/reverse gear assembly for a Radical racer.
Very well made stuff with tight tolerances.
At assembly we need to mount a ball bearing on a 37 mm hollow shaft, as the last step. The bearing is a very tight fit but removal ( press force around 40kN) was easy since we did not transfer any undue loads into the diff/planetary gear assembly.
Pressing it back on , which can only be made when asembly is otherwise complete, is different. No way to directly support the hollow axle to counteract the pres force.
Is it possible to heat a standard 2Z( rubber lip seal) ball bearing in oil to around 100 degr Centigrade , 200 degr F?
Best regards
Ola
Best regards
Ola
