Ball hex question
Mojave888
Is a ball hex actually designed to be used as a wobble? I know it can be as long as you don't crank on it. Or is the ball just to ease access to hard to get places and then used in a straight on manner?
Mohawk Dave
SoCal
I definitely use them on an angle all the time. And I've cranked on them, because, well, need to get them tight or loose and a straight one won't fit.
Bondhus and Snap on for me.
cmandp
New Jersey
Yeah sometimes you have to use the ball end to break things loose. I've used some of my small Bondhus ones to really crank down (as in with a small cheater)on small caps screws like 4-40 and they didn't break.
They will last longer without doing that though.
Empty Pockets
Rural New York
I have an older set of ball hex drivers with screwdriver type handles (CM by Western Forge). They are sure handy when you have to come at a fastener at an angle. I love them
rlitman
Long Island
Yes, the ball is meant to be used as a wobble. It is no stronger or less likely to damage a fastener when used straight on, then it is at an angle.
However, if you really need to crank on things, a ball hex may not be appropriate, as a straight hex is stronger.
bradleykd
Georgetown, KY
The best part about the ball end is how fast you can spin a cap screw out with you thumb on the short end.
The worst part about the ball end is trying to get the broken ball out of a cap screw in a spot that was so tight you had to use the ball end.
Dave455
Sussex, England
Yes, designed to be used that way. I've seen some of the manufacturers promotional material from firms such Bondhus and PB Swiss over the years, and some of it shows what angle you can work at!
Yes, sure, the ball ends are not as strong as regular, which is why I like to have both on my bench! I guess that's a very 'Garage Journal' way of doing things!
Diesel Mercedes
Newport News, VA
Having the gone through the horrible experience of removing the intake manifold on a 300SDL, the ONLY way to remove the intake manifold bolts is with a ball end hex.
And I had to put a long piece of pipe to break open those bolts that hadn't been moved in 31 years.
An amazing tool honestly.
Doug Arthurs
Ontario
Been there broke the ball off too. Almost impossible on a small one to get the ball back out.
