sierradmax
I'm in the process of rebuilding a set of dana 44 axles to a Jeep Wrangler Rubicon. I cannot separate the passenger knuckle from the lower ball joint. I used a pickle fork, heat, 3 lb. hammer, a jack on the bottom stud, ball joint separator, you name it. I simply cannot separate it. I've hit the knuckle so hard that the upper ball joint actually came loose and out of the axle.
Do I have any other option? Has anyone cut the ball joint to separate and press stud out of knuckle?
And yes, I have the castle nut off.
