ballast question
royce
fairbanks ak
Hello all,
I have some 2 bulb t-8 fixtures with 277v ballasts that I need to power with 120v.
I also have some 120v 3 or 4 bulb ballasts.
So then my question is, will these 3 or 4 bulb ballasts work on a 2 bulb fixtures.
Thank you
Mustang51js
Haskell nj
You can use the 3-4 bulb ballast but you can't use the 277 unless you have 277volts. The 120 ballasts you would just need to rewire based on the diagram on the ballast, you will just have some extra wires
alfredeneuman
Fullerton, CA
You can use the 3 lamp ballasts for 2 lamps.
T8 3 lamp ballasts have 1 black, 1 white, 1 red, and 3 blue leads
Simply cap off one of the blue leads.
