He all,
Upgrading the lighting in my new garage and have come across something interesting. I am replacing some 400w and 175 watt merc vapor lighting fixtures that use the large mogul bases with 6 bulb fluorescent fixtures. These fixtures are lithonia IB 632. I borrowed a couple older ones of these to see if the would light the area well enough for me to work...the ones I borrowed are older and have 2 white wires, 2 black wires and the green. Not too much of a riddle which wires go where...but when I turned the 1st one on to make sure it works the other mogul base fixtures in the series make a much louder high pitched noise than the typical hum when they are powered on also they cause enough interference to actually cause static on my FM radio about 20 ft away. Could this be bad ballasts in the borrowed fixtures or possible issues with mis-matched ballasts between the lithonia's and the mogul base fixtures?
