Red89gt
Guys hoping you can steer me in the right direction. I am in the process of removing metal halide hummers from my garage and replacing with nice quiet bright fluorescent tube T8's. The prior owner has one T8 fixture in a sea of annoying humming halides which leads me to believe he was starting to change over as the halides burned out.
Problem is this one T8 fixture is not playing friendly with my radio. I am guessing it is a commercial fixture as the prior owner did most things overkill. Is it as easy as changing out the ballast to get a residential version that won't cause interference? It is a 4 bulb fixture I would like to keep if at all possible.
Can this be bought at big box store and if so what part am I looking for as far as ratings?
Brands that are known better than others? i.e. Honda was known better than a Yugo
Whenever I changed ballasts in the past I just took them in and matched them up right in the aisle, went home and installed and never gave a second thought. I would like to go and buy and have on hand when I have a minute to climb up and change this out.
Thank you.
Thank you.
