band saw motor replacement 3ph - 1 ph
alex2929
I've been looking for a new horizontal band saw. I found a good deal on a wellsaw 1118. The guy said it was single phase.....my wife picked it up for me.....it is 3 phase. I am pretty good at electrical work but know nothing about 3 phase. Do I just look for a motor with similar specs as the 3 phase motor and go with it?
Yes ! As long as the motor frame (mount) is the same and the HP is the same, it won't be an issue (except wiring)
Or leave it 3 phase and buy a VFD and now you will have a variable speed band saw !
Walkers
Cave Creek Az
Another option is a Rotary Phase Converter. I have built several with a 3 phase motor and a kit from ebay for a hundred bucks.
A
alex2929
Thanks for the replies. I’ll probably go the new motor route. That seems the simplest. This is WAY more saw than I need but the price was right. It has a 3hp motor on it. I’ve seen some other used ones with 2hp. Would that work ok? This is strictly for hobby use
Zeke
3 HP for a band saw is a lot. Must be a brute. Is there a cooling flood system on it? Maybe they were running it fast. As for the weight, I wouldn't have thought of that off the bat but any kind of make up ballast will work. Put a lifting weight on it. Actually it would be kinda nice to slip weights on and off for different materials. I'm talking in ounces.
A
alex2929
It is a big saw. It has a hydraulic cylinder for down pressure and also a spring that can adjust so I don’t think a little variance in the motor weight would matter too much.
A
alex2929
Will some of this stuff need changed too? Motors definitely aren’t my strong spot.
yikes the wiring needs to be cleaned up a bit at the top.
yes the heaters in the overload relay block below the contactor will need to be changed if you change the motor
also you dont need all 3 poles since its single phase. you will need to make sure whatever 2 poles you use will have the line in from the breaker going to them. the control wiring for the coil will need to be rewired as well depending on which line in lugs it connects to...
Norcal
Adding a VFD is going to be the cheapest, the mag starter would need to be deleted but avoid garbage drives like Huanyang.
tool_scrounge
Southern California
does the saw have a shut off at the end of the cut? If it does and you say you are not good at electronics, buying a rotary phase converter is the simplest solution.
A
alex2929
It does have a switch to end the cut. It has a switch panel to turn the saw on/off and also coolant on/off. It also has a switch to end the cut
A
alex2929
And for what it’s worth, I consider myself pretty good with electric. Not motors or 3 phase though.
A
alex2929
From what I have figured out the pump and controls were not three phase. I have the parts book and it does not list those parts any different no matter what motor you have. You could buy this saw single or 3 phase when it was new.
The controls wouldnt be 3 phase since all youre doing is switching a single phase coil.
dave*99
Coastal NJ
A VFD is the easy solution here. Read up and price it out before you jump into replacing the motor. I haven’t bought a VFD in a while but the guys here will advise you on the correct brands.
jar944
Northern VA
I'll pile on the vfd suggestion. It's going to be far cheaper to get a name brand vfd than a new motor and mag starter / contactor.
The down/off switch is also a simple thing to wire into the vfd 3 wire external control circuit.
Norcal
On another forum the OP said he sourced a 1Ø motor for it.
fitter30
Peace Valley,mo
Look at the frame number of the 3 phase motor see if a single phase has the same number or call a motor shop they also make adapter base mounts. The sq d size 0 starter you have is rated to 18 amp so if the single phase motor is under that amps can purchase two heaters that are the correct amps and wire to the two outside poles and leave to middle old heater in.
Norcal
NEMA type starters do not work that way, they are rated for varying horsepower depending on the number of phases & the supply voltage, a NEMA size O is rated for 1 HP at 115V, 2 HP at 230V single phase, a single phase motor only requires 1 heater coil/thermal element, & when using a SQ D 3Ø overload relay in a 1Ø application, they offer a jumper kit to bypass the heaters in 2 of the poles, it is cheaper then buying 2 coils to use the kit, that way only have to buy 1, since the overload relay will not reset without either the heaters or heater & jumpers in place.
fitter30
Peace Valley,mo
Yes their rated for hp but they list overload amps. If it was in a industrial 3 ph setting not someones workshop a 1 ph proper starter would have to be purchased. I'll take the heavier contacts nema vrs definite purpose contactor with thermal overloads especially when the starter overloads are heaters.
A
alex2929
Boy this motor stuff is over my head. It intrigues me though. I have a motor shop getting a 1.5 hp motor ready for it. It was slightly used and he was going to go through it first. He thought it would be done later this week and would help me wire it up. He thought the starter/heaters would work for the motor. 🤷🏼‍♂️
Norcal
As long as it's run at 240V, and the necessary mods are done to the overload relay to use for single phase, it will fine.
