Paul_VR6
I am the proud owner of a lightly refreshed 14" Rockwell (Delta) 14" bandsaw. Model 28-303 w the adjustable speeds. Set on the outer pulleys.
I thought I had it set up decent with a 10/14 bimetal blade w tension in the range. Blasts through thin plate just fine.
I am cutting some 304ss tubing bends and i cannot keep the blade from getting stuck and popping off. Trying to figure out what my issue is. Waffled the blade yesterday when a part stuck bad. Internet tips have not helped so far. The only off one I found is that someone mentioned on these saws is the rubber on the wheels should only be used on wood not metal but no ref to this in the manual.
I have about 30 more cuts to do and popping the blade back on every two cuts is getting old. Help!
