Bandsaw throat plate
royce
fairbanks ak
Have an old 14"delta w/gear reduction bandsaw that needed a new plate, the recess in the table is only .100 deep.
The old one I had cut from soft aluminum and it finally gave way.
Found a donor piece of 1/2" 6061, which should be far more rigid, but won't allow tilting the table, which is fine by me.
I tried something new for me and taped it to a fixture plate, then cut it on the rotary table.
The double sided tape held fast and worked well.
Royce
cmandp
New Jersey
What kind of tape did you use? I've use carpet tape before and that worked okay but it wasn't a heavy cut.
