Stan Carpenter
- Joined
- Mar 8, 2015
- Messages
- 6
Made by Bardco Mfg. & Sales Co., Los Angeles, Ca - data plate picture attached. I replaced the power cord and cleaned a set of points inside the housing. It works fine. Good strong motor.
115 Volts, and "Los Angeles, 11, Calif, USA"
I'd say pre WWII; not sure what the "11" in the address Means...
The 11 is the old two digit postal code that was used in larger cities starting in 1943 until the ZIP code came out in 1963. So that grinder is 1943-1963 most likely.
Also, 8 amps is a pretty significant draw. I think the 1hp models on the Craftsman Block grinder thread draw 7+ amps. Looks like you got a rare and powerful one.![]()
Hi Stan,
Any updates in your search for Bardco grinder information..
My Bardco motor is 220VAC, and there is a transformer located in the square part of the housing, stepping up from 110->220VAC. I suspect they are all the same system.
That's interesting. Many bench grinders are dual voltage 110V-10amp/220V-5amp depending on how you wire them. I haven't heard of transformers for the conversion.
Disclaimer - I'm no electrician, just curious.
