klogan121
Barrel stove, nice pics with the IR camera! just got my stove up and running this past month.
When I installed my waste/used oil furnace, the instructions for the Simpson chimney said to use 500°F sealant to seal the double wall to the outside of the thimble. I called several places that should know, fireplace stores, etc, finally called Simpson, got the same answer everywhere, they could not recommend a brand or product, just that everyone used typical RTV and it worked fine. It seems no one had ever heard of Rutlands (at least they did not mention it) and I did web searches for 500 degree RTV and the like and could not turn up anything. I finally settled on a 425 degree RTV in a caulking gun tube from Home Depot and it seems to work OK, however, I have bookmarked the Rutlands web site and will keep it in mind if I have to remove the existing RTV and reseal the pipe.
Thanks for mentioning it.
Charles
Installed one of these this weekend as well, These things heat like a banshee.... After 2 hours my 30x40 is 76 degrees........
Nice setup! Did you make the air inlet tube on bottom yourself?
Barrel stove are extremely dangerous. The also work extremely well......
I want to burn drip waste oil into my simple barrel burner. Has anyone just rigged up a drum above the barrel and dripped oil in through drilled out hole in top of barrel? I plan to drill hole in top of barrel and pushing a 12" steel tube in to hole to fit snugly with 6" protruding in to the barrel and 6" being left sticking out of top of barrel. I would then lead a thinner copper tube in to the steel tube with a gravity oil feed controlled by a tap to drip feed into the barrel literally dropping oil onto the wood fire below. Anyone add few tips to improve on this for me. I want to keep it simple as possible.
