Barrett brake shoe grinder
wkeene
Homewood, IL
Picked up this true-arc grinder a few days ago and was wondering if anyone had, or knows of a source, for a manual?
If I break it down at all to clean it up I don't want to lose any calibration. It's a model B-375.
Thanks a lot
gba2331
I understand the words but have no idea why that machine is needed, could you edumicate me please? It sounds related to old cars and seems interesting….
disston
Silver Spring, Md
It is mostly for old cars. Anything really with drum brakes.
You'll notice on a new set of brake shoes for drum brakes the friction material is a even thickness through out. If used this way when the brakes are applied only a portion of the shoe contacts the drum. You loose efficiency. The act of arching the shoes matches them to the drum so when applied all the friction material contacts the drum.
It's a most desirable tool for anybody doing the brakes on old cars. Not a tool that everybody has, for sure. In the old days we would take the drums and the shoes to a shop that would do the arching for us.
Most often what happens is that mechanics that don't have this tool or access to one use the new shoes as is. It works. Danger may be brake fade if a heavily driven car. As time passes the shoes will arch themselves so things get better but that is thousands of miles.
W
wkeene
Homewood, IL
What disston said ... and the problem of just a smaller portion of the shoes making contact is worse with some repro shoes, at least with what I work on. And then that can be compounded when the drums are cut a fair amount.
gba2331
Is this arching across the inner & outer sides of the drum? I would've thought that the inside of the drum is flat from the outside to the inside.
If it is for the leading & trailing edges of the shoe, that doesn't make sense because the drum, shoe and backing should all be smaller concentric circles.
Skyman
Central Maryland
If the drum's radius isn't consistent across its face axially, this needs to be solved by either resurfacing (turning) the drum, or replacing it with new.
In an ideal world, yes, the shoes and drums would have exactly the same radii. Manufacturing variances, wear on used drums, etc, come into play. Matching the radius of the shoe to the radius of the drum provides full contact of the lining to the drum surface when the shoes are new. If this isn't done, the shoes will wear to the point that their radii will match the drums' radii, but initial braking performance can be sub-optimal.
disston
Silver Spring, Md
Asbestos is illegal on all new manufacturers. Back when this was a new thing my housemate bought all the old asbestos brake material he could find. Not finished shoes and pads but pieces of asbestos ready to fit. He was out of town when it arrived so I had to stack it all.
If you are working on an old car that last had brakes renewed in 10 years or more chances are there is asbestos involved. Also watch out for this in clutches. There are many other places where asbestos can be found on old cars like heat shields. Maybe inside mufflers? But I'm not sure about that one.
The danger is from breathing the dust. Other than that it worked really great.
W
wkeene
Homewood, IL
You're in a tight place. Many have asked for a manual and none show up.
Somebody that know about brake arcing says they are all basically the same. This manual was suggested.
Thanks. This Barrett is extremely intuitive to use, one practice shoe and (without instructions) I got it. What I was hoping for was a manual showing recalibration procedures. I think a good cleaning would do it some good and I don't want things to be off after reassembly. Right now if my drum gauge reads 10.03" and I set the grinder to 10.03", the ground shoe fits the drum very, very well and I'd like keep it that way.
W
wkeene
Homewood, IL
I think I have an old Ammco shoe radiuser up in the rafters.
Picked it up long ago but never actually needed it.
I was looking for an Ammco since I have an Ammco 4000, just so I could have a matching set. The lathe needs some reconditioning and reassembly though - cuz I need more projects 😄
skulldrinker
Bolingbrook, IL
I have two. 880 and 890.
