Good afternoon gentlemen,
I have a question in which i hope will be an easy answer for you pros. My house (built 2007) has a basement with the ac condenser drain pipe set to flow through a drain in the floor. It appears to also be used as a drain for the hot water tank. Twice now it has backed up. My question, is where does it drain to? I have attached a picture. I have checked and it does not flow into my sump pump which is a few feet away. (It is 100% dry)
I usually shopvac the hole out which will lead to a gallon or three of water. All clean aka not sewer. Does this hole just drain through the foundation to the earth?
Thanks in advance for help.
