Am starting to consider a basement floor re-do, a simple 1/8" self-leveling concrete overlay (like a Quickrete Floor Resurfacer over the exiting crappy concrete surface), then putting down some basic do-it-yourself epoxy from HD or maybe something a little fancier from a vendor here. Question is, do i need to do anything particular on the concrete surface prep since it'll be, effectively, new surface? Sq. footage is in the 500 or so range. FYI, the basement floor is generally dry, other than in a few sq. ft. of area where the concrete is so thin i can see dirt/gravel where small pieces are chipped away. On those particular spots/areas, moisture comes up (light dampness) during certain seasons. It's a very old house, but there is also a french drain, sump pump, new masonry on stone foundation walls inside & out. By the way my floor is all over the map in terms of level, so a mud job and tile is economically outta the question.
