Hi Folks. Just finished clearing out the basement...30 yd dumpsters worth
. Now it is still cluttered and I still have quite a bit of work ahead of me but it's time to start planning the floors.
I will be getting a foundation person in to inspect and repair a few small problem areas first. I am having some water seepage through some of the block so that needs to be addressed but for my part I am starting to plan out how to finish the floors. I need some suggestions, not only for finishing products but how to clean the 30+ years worth of dust.
I Started by doing some general sweeping to get the big stuff up. That kicked up a TON of dust. Once I got the larger floor debris up I broke out the shop vac with the hepa filters as the dust is so fine it is like talc. It clogged the filter in under two minutes, Swapped out for the general paper element filter with the same results which completely negated the use of said shop vac. unless I wanted to spend 2 minutes vacuuming and then 5 minutes blowing out the filters, then repeat..
This leads me to my first question. What is the most efficient way to clean these floors? I was considering a power washer but with no active drains it would be pretty labor intensive to power wash a section and then have to **** it up with the wet vac.
Secondly, What "finish" is suggested for a basement? I would love an epoxy style like you see in so many garages but we are talking about almost 1000 sq feet so that could get costly pretty quickly and I am doing this on a shoestring budget. I know that since this is a basement it is likely only going to be light homeowner usage. Basic workshop stuff and storage. Would an off the shelf floor solution be my best bet or any other suggestions? My biggest concern is smell. I do not want anything toxic or flammable floating around as I have a gas fired furnace as well as water heater. Flammable gases would be bad mmmkay..
I watch house flip shows on TV which makes me a professional contractor right? Seriously though I did see one in Hawaii where they did a beautiful stained concrete floor. It was brown and I would like something a little lighter but it looks like they have many colors to choose from. Would that be a good solution?
Thanks for any suggestions!
. Now it is still cluttered and I still have quite a bit of work ahead of me but it's time to start planning the floors.I will be getting a foundation person in to inspect and repair a few small problem areas first. I am having some water seepage through some of the block so that needs to be addressed but for my part I am starting to plan out how to finish the floors. I need some suggestions, not only for finishing products but how to clean the 30+ years worth of dust.
