Hey, all!
Been wondering about positing here, since this is a Garage forum, but folks seem to know a whole lot about floors here.
I am trying to figure out the logic of vapor barriers and how they interact with moisture. I am thinking of doing LVP for the floor, but first putting down a vapor barrier for some thermal break and moisture control. I did a sodium chloride test and came up with roughly ~4lbs of moisture per 1000 sq ft per 24 hours. There's one problem area with ~15, but I think I am going to leave that uncovered by the vapor barrier, as it's outside the main area I actually care about. This issue I will have to address some day in the future.
To the main point. So I have this moisture transmission, right? If I put a vapor barrier down, what actually happens to the water? It's still going to wick through the slab, and it will still condense underneath the vapor barrier, right? Is it going to reach some kind of equilibrium? I am having a hard time wrapping my head around the moisture that is now blocked from simply evaporating.
Side-question: would epoxy be OK with this level of moisture?
Cheers and thank you!
