scout308
Here are some photos of exterior wall in my partially finished basement.
This is standard block, filled with concrete and some rebar. Its under the porch. Its painted with Killz when new. House is about 3 years old. On the other side is the dirt/front yard.
It got this way over time and hasnt obviously gotten worse.
Is this drying or moisture coming thru? Enough to worry about?? Thoughts?
Plan is for this to be safe room and have gun safe inside it. Have steel door between it and other room. Have had a dehumidifier in it since finished. It is set on 55% and rarely runs now. The room has central ac/heat run to it but it stays 62-65 year round in the basement without ac or heat running, so I mainly leave the system fan running to keep air moving.
Any suggestions for prep before putting up cabinets or shelving that may cover the wall? Drilling and screwing into it?? I would like to mount cabinets and some slat wall, so that would require some studs or something to mount to wall, insulate in between? moisture barrier? any advice?? Thanks in advance!
