Basement wall paint
green2kgt
North Central Ohio
I put this here b/c it could be used for garages too. My foundation walls in the basement of my house need painted. They are a beat up ugly gray and you can see a lot of patches that were made. Can you guys recommend a cheap paint to use that will adhere good and be hard when its dry? Or do I basically just use a cheap oil-based paint?
Thanks
Garage Coffee Roaster
Pittsburgh, pa
Drylok. It seals out moisture and adheres well.
Make sure you clean the walls with TSP and water or used a wire brush to remove all of the efflorescence and let dry a day or two. If you do not prep the paint will not adhere properly.
Jim
G
green2kgt
North Central Ohio
Jim
TSP? is this is?
http://www.homedepot.com/p/Klean-St...hate-Substitute-QKTP06/203146063#.UkHNaCbD-Uk
found this...
http://www.homedepot.com/p/DRYLOK-1-Gal-White-Masonry-Waterproofer-27513/100118662#.UkHMyCbD-Uk
and thanks a lot for the info! Ill use that paint and cleaner.
