Basic electrical code/practice question
hunttuxcat
Very basic question, looking for some input.
obviously best practice is to wrap a wire clockwise so when you tighten the screw it tightens the connections.
however, if there are a couple instances where the wrap is counter clockwise, is that an Esa fail? Even if the connection is secure?
trying to understand if some of the defects I've seen are code violations or just examples of poor practice that are inadvisable but not violations.
Zeke
I find that with solid wire #10 it makes no difference if your brain farts and you do this. # 12 almost. 14 might spread open most of the time. However, I do a lot of bench electrical repairs with stranded. I learned to twist the strands counter clockwise then loop them clockwise around the screw. Helps to hold the end with needle nose if you have the dexterity and room.
Bicycle cables have these little sleeves at the ends to keep from fraying. Someone ought to make mini crimps for stranded. 1/8th inch.
Nothing like having a wild wire (wild hair) able to touch something it shouldn't when you power up. When you take things apart you see everything from neater than you can do to the worst bird's nest possible. That's what's fun about electrical work. So many ways to do the same thing.
SlappyWhite
Upper Canada
Code questions without a location are not useful.
My guess is Ontario (ESA) but OP should confirm... Not sure if other jurisdictions use the same acronym.
If nothing else it will potentially make a bad connection. It is taught that way even if it is or is not code.
And +1 on ain't nobody got time for backstabbing....
RPH
Michigan Thumb
Like these?
Mzungu
It used to be in the Canadian code, but regardless it's also a matter of good workmanship. As for backstabbing don't even get me started.
RPH
Michigan Thumb
We used them in the control panels depending on what standards the customer required. Low voltage to high voltage, 24 vdc to 480 vac.
mrpizza
IL
What about the outlets you can wire straight from the back but have to tighten the screw plate down on?
sparky 1971
Central Iowa
That isn't backstabbing, it's back wiring. It may seem the same but they are different. Backstabbing is relying on a phony little spring terminal holding the conductor in place and making contact.
