FakeName
Finally moving forward with my delayed garage project, and am putting together a budget.
The walls and ceiling space in the garage are completely uninsulated and bare. I've thoughtfully attached a couple images. It is my intention to sheetrock the walls and ceiling, but I'll obviously need to install some insulation.
So.
What do you suggest I use? Remember, this is a garage in San Diego, where it rarely reaches below 40 (WAY TO COLD!) and is above 80 only several days per year. I will be using a 2400 BTU (iirc) ductless AC system.
Of course, the killer blown-in insulation from a top-notch installer will be best, but may break my budget.
What would you suggest as a reasonable value for insulation here? Should the stuff go on top of the drywall in the ceiling, or attached directly to the roof?
Thank you.
The walls are 2x4 framed. I can only speculate why some previous owner painted the interior with silver- if I had to guess, it'd be a grow room. ; )
The exterior is stucco, and the garage is about 284 square feet.
So.
Thank you.
