Basic lighting setup for 1 car garage
drew2000
Hey Guys,
I have a one car garage that has a single 60W bulb in a fixture. Clearly, I need to upgrade it with some tube lights or something like that. I know about the screw-in adapters for the light sockets, but I am not sure if I want to go that route.
Does anyone have a recommendation for an entry level tube light system with an easy, clean install?
Thanks,
Drew
pattenp
Virginia - USA
You can use the wiremold system (not cheap) and add some outlets on the ceiling for plug-in 2 tube shop lights.
hill^top
I just got some 6 tube high bay lights at HD for $80ea. without the T8 bulbs. They make the area under them suitable for any garage operating room.
D
drew2000
That's funny, as many times as I have been to HD and Lowes, I have never seen any tube lighting. I will check that out.
Are T8 tubes preferred over other types?
I actually have a plug-in outlet on the ceiling. One plug is used by the garage door opener and the other is open.
I will look at the Raceway system too.
Thanks,
Drew
pipsters
USA
Change the light fixture to a two or 4 plug receptacle and buy some 4' shop lights that plug into it (buy the more expensive $20 ones, not the $10 ones). You can put the cord in conduits. That is what I did, and I like having several 2 bulb 4' lights as you can position them in various ways which prevents shadowing.
D
drew2000
Thanks!
Follow-up question: Don't the 4-plug receptacles require two sets of wires coming from the house?
I'm sure there is only one pair + a grounding screw up in the box behind the light fixture.
Thanks
Drew
