Basic question about torque
LostHSV
Alabama
Do you lose torque foot pounds (+/-) if you use an extension on a torque wrench? For example, doing spark plugs with a 1/2 torque wrench (with a 3/8 adapter) or anything that is hard to reach and should be torqued. Not all of us have multiple torque wrenches to choose from. Thoughts?
Stephenw
Utah
No, unless you change the axis of ratation such as when using a crowfoot or torque adapter.
PorscheTech
You will only change torque by adding extensions on air or electric tools. A common torque wrench with extension will not be effected. If the head of the wrench is not straight on as in tweaked a little that will effect it also. Just make sure heads on good and flat, and torque all day with extensions.
Wakefield
Arlington VA (but would like to get out to country
I worry about torque going through universals and swivels. I think the more bend at the joint the less torque gets through. But an engineer said it could be more! Maybe the double swivel spark plug getter acts like a double cardan u-joint and works better? I can't get a straight line to my under the cowl spark plugs-maybe there is such a thing as a stubby 3/8's drive Torque Wrench?
Danglerb
SoCal
You can get torque limited sockets just for sparkplugs, then use any drive you want with them.
