Greetings all. I've read through a lot of threads here and couldn’t find exactly my case, so here goes:
Sending wiring to a single-car detached garage.
I plan to go from a 20A breaker in the house panel, then use NM-B 12/2 (12-guage 3-wire) through the underground PVC conduit which was just laid.
In the garage, I will have a junction box (not a breaker panel) which will feed 4 lines: 1) GFCI Receptacles, 2) Light switch (1 or 2 bulbs), 3) Garage Door Opener, 4) Light switch for external light.
Distance from house panel to junction box: 65'.
Here is the map:
House panel->-----(38ft)---->8 inch brick wall--->LB connector ---->underground 1.75" conduit 27ft-------->LB Connector ----->Junction box
Notice the plan is to go straight from the house panel to the garage junction box (no intermediate splices). I plan to use indoor Romex for the entire run as it is never exposed to weather.
1. Do I have to use 4-wire? Somewhere I read that you need to run 4-wire to the garage. I have no plans for 220V/240V usage.
2. Can I use a junction box or do I have to install a breaker panel?
-g
Here is the map:
-g
