Basic tool kit recommendations
Blanco_25
I work on small engines as a side job , work on my own vehicles when needed .
I have misc. Snap on ,matco ,Mac bits and pieces that my dad owned but trying see what everyone recommends for when the tool truck shows up .
Thanks in advance .
Blanco_25
Snap on. 1/4 ratchet misc SAE and metric sockets , snap on 1/2 ratchet , snap on screwdrivers and nut drivers , Mac wrench 9/16 and 15/16, misc wrenches.
ChaseDE
Delaware
I mainly just work on my own cars, not a mechanic per se, and my neighbor hooks me up with the small engine stuff like carb rebuilds.
that said, all i needed to get by for years was a decent craftsman set that included 1/4, 3/8 sockets and ratchets and come wrenches.
something like this. http://www.sears.com/craftsman-230-...SellerId=Sears&prdNo=1&blockNo=1&blockType=G1
yeah i know it's probably made in china and its cheap and they are going out of business. that set or something like that got me by for years just putzing around in the garage.
you can see the set i have in its cheap plastic blow molded case here on the left table.
You will end up buying more wrenches more then likely. like honda oil drain plugs are 17mm usually so you get a set of bigger metric box end wrenches.
then you need to change your mower blades and need a huge wrench for that, you accumulate what you need.
That is how I did it until I inherited my grandfathers tools. now i have loads of standard everything and a lot more then i need really.
that crafstman set is capable though. really it depends on your budget and how much you do in the garage.
M6erfan
'Merica!
"Basic" can mean different things to different people. You didn't mention a budget either...
From what you describe, you'll want a complete 1/4" & 3/8" socket set in both Metric/SAE. Extensions. Torx/Hex drivers/bits. Combo wrenches from 1/4"/6mm - 3/4"/19mm. Spark plug sockets. Basic Multimeter. Side cutters, long nose pliers, Channellocks or Cobras. lug sockets. Breaker bar. Torque wrenches. Dead blow ball pein, soft head mallet. Hand impact driver.
These are the "basics" in hand tools and will get you by for 95% of what you want to do. Add other tools as you find you need them.
Here are some suggestions;
https://www.amazon.com/TEKTON-18792-Combination-Wrench-Keeper/dp/B00OZJMWT4/ref=sr_1_3?ie=UTF8&qid=1475701222&sr=8-3&keywords=tekton%2Bwrench%2Bset%2Bset&th=1
https://www.amazon.com/TEKTON-13101-8-Inch-6-Point-16-Inch/dp/B00RCYX504/ref=sr_1_1?ie=UTF8&qid=1475701097&sr=8-1&keywords=tekton%2Bsocket%2Bset&th=1
Bessy
Ontario, Canada
First off, why are you set on truck brand tools exactly? Do you "have a guy"? For the most part, particularly with respect to small engine and occasional vehicle repair/maintenance, are you really going to see the pay back from buying truck brand tools? I could understand if you were using them professionally, or if you were talking speciality tools where truck brands may be favourable, but for most hand tools it's probably overkill. Make of it what you will, but unless you are making a killing on the side doing small engine work (which I find a reach) save your money and stick to tools that have a decent in store warranty coverage. I can't speak much to the USA equivalent, but in Canada, Mastercraft Maximum and to some extent their basic Mastercraft lines of tools have suited my uses well for years of doing regular maintenance on mowers/trimmers/blowers/etc and the occasional maintenance work on my vehicles.
Now as for small engine repair tools, some things I would recommend to buy include:
- Angle Grinder for doing quick blade sharpening, the trick is that you can do most riding mower blades without even having to take them off, as long as you are careful!
- Bench Grinder for doing blades in a slightly safer and neater fashion.
- Chainsaw sharpener for saw blades, particularly if you can secure a contract with a landscaper or arborist who may want 20 or 30 chains done at a time
- Spark Tester
- mini screwdriver set
- Tire plug kit, some extra valves and a valve tool (one of the four way tools you can pick up for probably 3 or 4 bucks at any big box tool store)
- 1.5" rigid and flexible scrapers for doing deck cleaning
- a set of hand files for doing axe blades, and any finish work on blades for saws etc.
- I'd keep away from 1/2" drive stuff until you really need it, and even then unless you are getting into professional grade machinery, you won't see much stuff that big except on deck spindles for riding mowers.
most hand equipment these days is going with torx bits for a lot of things, so a 3/8" set of torx is really nice to have, grab a set of Gear Wrench combo wrenches, maybe a socket set that covers 1/4 and 3/8 inch stuff and you'll be mostly set as far as basic goes. from there on, it's only tools that make certain jobs easier that you can add on as the need arises.
Now if you get into rebuilding engines entirely, a spring compressor, ring compressor, ring pliers, c-clip pliers, feeler gauge set, micrometer, and 3/8 and 1/4" torque wrenches are necessary on top of the existing stuff, but those jobs are becoming few and far between given the throwaway nature of most lawn and garden equipment these days.
joel63
Central FL
What brands of small engine do you plan to work on?
2 stroke or 4 stroke? This will determine some of the tools you will need.
You will find a spark checker very useful.
Flywheel puller.
gdocktor3
Connecticut
My advice - buy the Gearwrench BOGO deal with 1/4" and 3/8" socket sets http://jmcautomotiveequipment.com/gearwrench-1-4-and-3-8-socket-set-promo-pack/
Then buy the 41 piece Craftsman screwdriver set to cover torx, flat, phillips. http://www.sears.com/craftsman-41-pc-screwdriver-set/p-00931798000P?intcmp=crft-pdp-buy-cta
Lastly buy the 20 piece Gearwrench ratchet wrench set http://www.sears.com/gearwrench-20p...SellerId=Sears&prdNo=6&blockNo=6&blockType=G6
Grand total of roughly $210, probably cheaper if you shop around and use discount codes, etc. Gearwrench tools are right up there with professional quality and Craftsman screwdrivers, while still made in USA, get a bad reputation on here from some, yet nearly every garage/shop in America still has Craftsman screwdrivers in their tool boxes. Craftsman also sells USA made (Western Forge) adjustable wrenches, groove lock pliers, needle nose pliers, wire cutters, punch & chisels, as well as hammers, bolt extractors, 6 point ratchet wrenches and more, that are all EXCELLENT quality tools. The pry bars are also made in USA by Wilde. I would buy as many of the items you need from Sears, as long as they're made in the USA. I did.
Greg85mcss
Frederick MD
https://www.amazon.com/dp/B00OZJMWT4/?tag=atomicindus08-20
https://www.amazon.com/dp/B00RCYX504/?tag=atomicindus08-20
I have the set in the 2nd link. Keep it in my car with a few other tools. It's just about perfect for around the house & smaller mechanical stuff. I also saw torx mentioned. I've had my eye on some vim sets for a while. They're the oem of a few truck brands. Tbh the ones that came in my craftsman set have pretty much done everything I've needed so they haven't made it to the top of my list yet.
