Bathroom door casing material - wood or PVC
branimal
I have a door casing that is fairly close to the bathtub. It's a small bathroom and this was the only option that works. I'm going to tile right up to the casing.
What's the best material for a casing that will see moisture? PVC or wood? Or something else.
Toomanytools?
Washington
I've rarely had issues with a real wood product as long as it is painted and either paint the bottom so not to wick up water or leave an 1/8" gap and caulk. If it is getting wet from shower curtain or such, PVC is a good choice but profiles are limited.
burleyfarm
Northern Michigan
Just don’t use the MDF trim. Son bought a house with it in the bathroom. Had to replace all of it as it swells in humidity.
kd3pc
Northern Neck
keep the wood clean, caulked and painted and it should do well. TooMany describes what we do.
The last house I owned, the tile setter was so good with the tile edging the tub/shower that I only needed to caulk the 1/8th in gap. Job well done, no trim at all.
yeldogt
Wood trim is fine .... wood can get wet. It just has to dry
CraigStu
Blacksburg, Va
PVC every day. Why go to extra steps to protect wood and worry about it over the years? I don't really like the PVC because the dust is horrible but next to a shower I wouldn't consider anything else.
speed bump
Butte Montana
I have done a bathroom with PVC, one with wood, and one with MDF. I did the PVC one first and I don't think I will ever do that again, it's more work to make it look nice compared to wood and I couldn't get it to take paint very well. The second bathroom I did with poplar and painted with SW paint, and it held up fine. The third one I did with MDF because that was the only material I could source locally in the profile I wanted and painted with SW Emerald trim paint. This bathroom has MDF casing up the side of the tub surround and no sign of any damage after 1.5 years.
My advice is seal wood well, make sure the vent fan gets used, and you should be okay with whatever you choose.
