Bathroom exhaust fan?
bruincup
Alberta, Canada
I have another project but its not in the garage. There's so much knowledge here and I can't seem to find a decent home improvement forum. Is it OK to stray away from the Garage? Asking first, I don't want to piss anyone off.
bruincup
cjn1014
need to replace a few as well. anyone recommend an existing construction, low noise model (DC motor?)
yeldogt
I like Panasonic for replacement and Fantech for new ... normally install a timer switch.
James-W
Southeastern Wisconsin
I don't have a timer switch, but I wish I did. It is a very good idea to have the fan turn off by itself. Many times the wife doesn't turn off the bathroom fan and it will run until I hear it running and then I turn it off. I have told the wife on numerous occasions to turn the fan off after a few minutes, but for some reason she seems to ignore me.
sourdough
Pe Ell, WA
Don't feel like the Lone Ranger! It happens more often than not in this household.
I might investigate a timer for the fan. It might aggravate my better half, but we live in a very humid climate here in SW WA especially in winter. Thinking about a timer that will shut off the fan in 15-20 minutes.
These fans don't pull a lot of KW usage, but that is a little bit of something that can be used elsewhere.
We have propane-fired forced air heat and I always (as a retired guy) wait until the house t-stat makes (68* set-point) for a few minutes before I take a shower in the morning to insure a warm bathroom when I exit the shower.
(The cat likes it very much also, laying in front of the vent!)
Good Luck, Sir!
Jim
LS6 Tommy
Northern NJ
I'm really happy with the Fantech in line fans. I set them up powered from the bathroom light. No need for a timer that way.
Tommy
the gypsy
Montreal, Quebec, Canada
I installed a timer so that the lingering smell, after you leave the washroom, can still be expelled. Also because there is still humidity in the shower after you are finished in the washroom.
McFarmer
We have an old farmhouse, when the bathroom was put in it doesn't have good exterior access and no vent was installed. No problem I til I put a shower in, then we had humidity problems.
Against my wife's best advice I cut a hole in the floor, ran a 6 " PVC sewer pipe nearly to the ceiling, painted it, installed some towel hooks along the way and put a fan in the basement. Then out a basement window. Very big fan, hardly any noise. Separate switch, timer would be nice.
malibu101
Walnutport PA
Inline fans were mentioned above. So I just wanted to say........
I installed the below Nutone inline bathroom exhaust fan a few years ago when I remodeled the bathroom as the ceiling joists were not tall enough to fit a "normal" fan in.
It works very well and is not real noisy, as compared to some fans. But I expected less noise with the fan being remote mounted in the attic via about 6' of ducting.
http://www.nutone.com/products/product/590b892c-41be-427a-b280-f5ab378b9d73
To the OP- What is your question?
yeldogt
fantech makes the majority of the inline fans -- many of the other inline units are rebadged fantech. I like the exterior mounted fantech ... I have been using them for almost 20 years - all the noise is outside and they have enough cfm.
Normally I put in two small round inlet grills -- one in the shower and another over by the toilet -- fantech makes a kit with all the parts -- back-flow preventer and the "Y" etc. Quiet and almost invisible set up.
The timers I use are the electronic pushbutton units -- 5/10/15/ 30 min countdown. around 30 bucks -- they fit the decoria size plate (they need a neutral). I don't need or want the fan to go on with the light ... and you want enough cfm's to get the job done. The timers stop wasted AC and heat going outside.
pseudorealityx
USA
Code requirement is 50 cfm for a toilet, just fyi.
I don't mind a bit louder fan, as it tends to mask some of the other 'sounds' that come out of the bathroom. Especially if you have a half bath closer to your living/dining room, it's something to consider.
LS6 Tommy
Northern NJ
Never thought about the "afterodor". I don't have an issue with humidity. I used one that had something like 150 cfm @ .2" static. You can't fog the mirror in that bathroom when the shower is running...
Tommy
Todd.Brock
Cincinnati
I looked at the Panasonic fans and they are incredibly expensive I think I found one for 200 bucks? We have a skylight and it captures humidity we have water marks running down the wall above the shower. There isn't even a door on the bathroom !! ( yet).
I need a fan that is silent, has a humidistat, and will retrofit into an existing ceiling fan location. I have the standard crappy builders grade broan fan and currently. If 200 bucks fixes the problem that I might have to look into the Panasonic
east_tn_emc
East Tennessee
Another vote for Panasonic. The 50cfm is a joke. I put a 300cfm in our small ~32 sq ft bathroom. No moisture after a shower. Wife likes it when cleaning the shower as the cleaning fumes are sucked out too.
It is quiet and was easy to install.
RECox286
South Joisey (yeah, that is part of the USA)
What ? You don't have kids ? Just wait ! Sometimes I feel like I have
one shoe nailed to the floor...
Uncle Bob
bruincup
Alberta, Canada
bruincup
This forum is awesome. Gone for a couple of days and away we go. I have 2 existing exhaust fans to replace and was just wondering what was the ones to go with. Existing fans are Broans and they are not real powerful, maybe just getting old. Anyways the brands I have been looking at are Panasonic, Fantech, S&P and DeltaBreez. The website I have been reading at is HVACQuick. Thumbs up for all of the replies.
bruincup
MDSPHOTO
Oz
I put a Hunter designer fan/light in our master water closet and it looks and sounds great.
