Given the analog design, like a needle volt meter etc, you simply tweak the screw below the display to 'zero' the deflection. I used my Fluke meter to benchmark the voltage and adjusted the HF load tester accordingly. Takes seconds
I pulled that old 100Amp HF load tester out of storage to revisit this.
So when the tester is not hooked up, it is centered at 0V. When I attached it to an unloaded test battery, it reads 12.7V - exactly the same as a multimeter on the terminals. Everything seems to be as it should be.
However, when I apply the load, the analog gauge on the load tester drops to 9V, while a multimeter (multiple different ones) on the battery terminals reads 9.9V, which is a 0.9V difference.
So there is a 0.9V drop between the load tester’s cables and its analog meter under load. idk, maybe when I get out to the garage again, I’ll put a dc amp Clamp on the cables to see how much amperage the load tester is really drawing. Having discrepant numbers makes me question the reliability of my equipment.
