duwem
Sorry, this is house related not garage, but I don't want to join yet another forum so here it is.
Had an incident this year where the float hung up on our electric sump pump and flooded the basement (not bad, but 2" of water is enough to saturate the carpet and weep up all the drywall walls and anything sitting on the carpet.
Talked to a few plumbers about battery backup and got some different recommendations.
This was one:
https://www.stopflooding.com/phcc-pro-series-2400/
Kind of sounds like it runs on 120v till the power goes out, then runs on 12. but maybe it just uses the power invertor to take the 120 to 12v. That feature would be nice vs one that just runs on battery, that way if primary 120v pump fails for other than power outage. this one would run on 120 for a while and not **** the battery down.
This is the other one:
https://www.zoellerpumps.com/en-na/products/back-up/battery-powered/aquanot-508
It kind of ties into the primary pump with plumbing, there was one or 2 complaints about the coupling being a weak point.
Both pumbers mentioned there was the option to upgrade to a gell cell battery vs lead acid. I have read about people having to top off the lead acid batteries once in a while to keep them alive, would pay extra to not have to deal with that especially if the gell cell will last longer.
I'm not tech savvy, but some have Wi-Fi options and cell/email alerts. I guess my simple mind says if the power goes out, then the Wi-Fi router is out and it wont work?
Thoughts?
Thanks
This was one:
Thoughts?
Thanks
I looked at the sump during a few heavy rains, and it was essentially dry, which put my mind somewhat at ease. I still worried, since the previous owner disclosed that the basement had flooded 3-4" during a storm a few years earlier due to a pump failure.
