passinthru
Trying to repair my old sears 6/12v 2-10- 60 amp charger.
I am electronically challenged so be kind.
I believe my diods are bad,there suppose to test over .5 and mine are at .472
So I read here about using a bridge diod in its place,but it didn't ex plane how to wire it. Well I bolted my new bridge diod to the heat sink, used the 2 prongs that weren't marked +or - for the same 2 wires that went into the old diod, pluged it in, and in a second or two smoke was coming from the diod connections.
I thought well you dummy you have to get the power out of the diod into the heatsink....So I bolted a wire to the heatsink and tried it on the + and - post of the diod with the same smoking results on both.
I dont know if what i did fried the diod or if i'am still doing something wrong.I have another diod to try if I knew for sure how to wire it.
Thanks for any help
Thanks for any help
In my defense I thought the wave symbol was a messed up negative symbol so used the other 2 for my input
