Battery charger recommendation for rust removal
tool_scrounge
Southern California
Well my old battery charger was borrowed once too often and has disappeared. So I need to buy another one. In addition to the usual charging battery duties (usually someone else's I might add), I would like to use it for rust removal purposes. Most of the stuff I need to remove rust from is 50 lb vise size or smaller and I do not need super speed. New or used is fine. Do you have any not smart battery charger recommendations?
Thanks!
Lhorn
Google "electrolysis" or check it out on youtube.
Edit: ah I see you found it.
I plan to use a power supply from a computer.
454ragtop
Carver, MA
If you use a car battery in conjunction with the charger, most any charger will do, even a "smart" one. I find I get better results this way, even with an old "dumb" charger.
Jim
SeattleKent
Redmond, Washington
I use a Sear "DieHard 10 amp Manual Battery Charger". It is Sears model number 71221. Gives you a choice between 2 amps and 10 amps. I'm currently using to restore an old Snap-on tool box. Also doing motorcycle parts and old tools. Works very well. Cost about $35.
SteveL
St. Louis, MO
Pretty much any 12v power supply that puts out 5 amps or more will work just fine. I use a 12v/30 amp supply that I used to run R/C car battery chargers for years when I raced them. Works almost too well as you have to be carefull not to leave the part in too long.
The key is to use Arm & Hammer washing soda for your mix. Lots of info on the web for the process. I've used it to restore a '39 Delta Uni Saw and a '43 Delta jointer using a concrete mixing trough from HD and rebar for the electrodes. The trough was deep enough that I could do half of the table saw cabinet and then flip it over to do the other half.
T
tool_scrounge
Southern California
Thanks for all the recommendations. Last night I got a lead on a quality used battery charger so I will check it out. Otherwise the Sears or Advanced Auto ones look pretty good. CIt is good to head a PC computer power supply would work. I need to get a battery charger anyway so I'll start there. I'll head over to Vons and pick up some Arm & Hammer Washing Soda - from everything I read it works better that baking soda.
I have also read that carbon electrodes work well and do not foul like rebar? If that is the case, my next search is for a source of carbon electrodes. Thanks again!
pipsters
USA
Walmart sells "washing soda" in the pool chemicals department, forget the name but look under the pool chemicals for a "ph" adjuster. Active ingredient is sodium carbonate or Na2CO3. You can get a lifetime supply for $10.
Bunk
Alexandria, VA
+1 on that recommendation.
I have no personal experience with using a computer power supply, however, I have seen/read about some people having experiences with them not lasting terribly long. I chose the inexpensive Diehard charger route because of that.
serviceguy
Would the DieHard battery charger work well for zync plating ? The electrolysis process should be the same but in reverse. Would the washing soda work for that process as well? Just started looking into it after playing for a while with biodegradable rust remover.
T
tool_scrounge
Southern California
Thanks to everyone for their recommendations. As I was about to buy a new Sears charger, I ran into this 25+ year old but barely used Schauer Model CR312 10 amp battery charger (US made). As you can see in photo, it has switch for manual and automatic charging modes. So I will be useful for both rust removal and automatic battery charging. I am sure the new chargers are probably more sophisticated internally, as this one is mostly transformer with a bridge rectifier, a few discretes, and a regulator. I'll probably add a small AC fan fan for good measure.
SeattleKent
Redmond, Washington
Looks great. The amps meter is super helpful. I sometimes get thing all set up perfect. Turn on the meter and is shows 1 amp. Then I know it is not perfect after all. Maybe a corroded wire or a loose clip or rust build up on the plate. Let us know how the electrolysis turns out.
