Battery charger ?
aka rotten
Answer question for an 85 year old who knows nothing bout electric.Is 2 amp enough to light a tester if I touch the probe to positive side of battery charger,other to neg.lead.Reason I ask I get nothing ,yet 12 amp and 50 amp work fine.2 amp seem like it died.Thanks
G_P
Central CT
Is it a slide switch to select the charging amps? If so the switch may be dirty/corroded or the wire on the 2 amp setting has broken off the switch.
A
aka rotten
K,2 amp & 12 amp on same switch [flip type ] 2 amp top ,10 bottom,Starting battery 55amp starting& marine on another switch.May have to take apart and blow out mabee dirt as you say.Thanks for help.
Zelatore
Walnut Grove, CA
Many modern chargers will show no output if you try to measure across the leads when they are not connected to a load (battery). It's a safety feature to prevent sparks or shorting of the leads. The charger won't turn on unless there is a load attached.
This is also why some of them won't recharge a totally dead battery. If they don't see at least 4 volts on the leads they think they aren't connected and stay turned off.
A simple solution would be to find a battery, measure the voltage on it, then hook up the charger and see if the voltage goes up. This would of course work best if the battery wasn't totally charged already.
justsam
Penngrove, California
Is this a single charger that has a 2, 12, and 50 Amp charging rate or are these individual chargers?
I'm with Zelatore, in that many new "Smart" chargers will output nothing unless they see a load with some lower threshold voltage to trigger them. Best way to test here would be to measure charging CURRENT as opposed to seeing if voltage is present.
