Battery Charger
bobcatdan
Kaukauna,WI
I have never found a battery charger with the boost function that did ****. Perfectly happy with little bench top Schumacher's. I charge everything slow so major amperage isn't important to me. If something is dead and I need it moving now, jump it with the jump back and make the alternator work its **** off.
WhiffySpark
I know everyone will give me ****, but I love my snap on one. Boost actually works on this one it turned my 3 cyl diesel over easily.
CJM8515
2 separate things are needed. A good booster is much more worth it than an all in one unit. Unless you need to turn over diesels frequently, the JNC 660 is seriously the towing and automotive standard. Simple to use, idiot proof unless you hook it up backwards and can charge it off a vehicle or a wall socket. Also only about 120 bucks.
The best tender charger is the battery tender brand, they cant be beat for the price.
brownbagg
I never been to happy with Schumacher's but that about all you can buy, yes i burn up a couple and i still buy schumachers but there really nothing good out there
I have never found a battery charger with the boost function that did ****. Perfectly happy with little bench top Schumacher's. I charge everything slow so major amperage isn't important to me. If something is dead and I need it moving now, jump it with the jump pack and make the alternator work its **** off.
WOW !!! 3 perfect suggestion.
You can find Schumacher chargers at Sears, Kmart, Menards and most places like that.
CJM8515
Oh btw, dont use the cars charging system to recharge a dead battery. Not only does it damage the battery rapidly recharging it,b ut you can damage the charging system.
Oh btw, dont use the cars charging system to recharge a dead battery. Not only does it damage the battery rapidly recharging it, but you can damage the charging system.
Let's be realistic. You go some place and accidentally leave the interior lights on in your car ... overnight. AAA will jump you and sell you a battery (at an outrageous price) or you can just drive.
Perhaps not the BEST solution, but it does work. Also modern (<10 years old) charging systems are better at estimating the state of charge on a battery. They don't charge them at tye same rate they did in the "god old days" (sometimes > 15.0V !).
CJM8515
Use the car to recharge it and you can damage charging system and battery. I see it daily since i drive the AAA battery truck.
I had a guy do it 2x to same Honda Civic. Dead battery refused new one and 3 hours later bad alternator on a 45k mile and 5 year old car. ***** did it again 2 years later
Also it's not so ridiculously priced. Walmart is only 10-20 bucks cheaper at best and most people can't do the job themselves. Walmart around here doesn't install or even have an auto service center.
gungatim
west mich
The HF ones work just fine.
I agree, they work well until they die. when they die, I pull out the circuit board and put in a radio shack bridge rectifier (around $7, I bought a bunch before they went **** up) and a small computer fan mounted in the case (just tap off one of the 12v or 6v wires from the xformer). no longer automatic but will work forever that way...I tend to burn them up fairly frequently, but that's just me...even adding just the fan to any of the benchtop chargers is a worthwhile mod....heat kills them...
DonPowers
On The Hair At The End Of The Dog's Tail
jgorm
San Diego
I have lots of chargers. I use a electronic controlled charger if I plan to recharge, but not come unplug right away. All transformer chargers can overcharge if you leave them on. I also have multiple battery tender chargers I have used for years on vehicles I don't drive every week. I have a 200a booster charger for jumps and compression tests. I also have solar chargers that work like battery tenders for vehicles outside. Never let a battery go past 50% capacity. Keep them topped off and don't leave them on anything over about 1 amp for more than 24 hours unless it's a microprocessor controlled charger.
bobcatdan
Kaukauna,WI
If you ask an alternator to charge a run down battery once, its not going to hurt it, especially if a battery is just weak enough to not start start something. If it's a battery down around 6 volts, then simply jumping it not a good option, why is the battery that low and that needs to be solved before the car drives away.
CJM8515
Agreed. Problem is most are lower than 8-6v because people leave things on overnight by accident. I see it daily, very large senior communities around here and they continuously ruin batteries in this manner. Actually most people run down the battery in a similar fashion, we have repeat offenders that just keep calling for a jumpstart and dont understand they ruined the battery by draining it down and using the car to recharge it. Usually by the 3rd or 4th time the alternator is done. Its awesome telling them that if they had listened they wouldnt be out 500+ bucks (alternator, labor, and new battery now)
Also (AAAabttery) it's not so ridiculously priced. Walmart is only 10-20 bucks cheaper at best and most people can't do the job themselves. Walmart around here doesn't install or even have an auto service center.
It was at least $70-$80 more.
Bobf
Poway, CA
Gee, I've had a 6/12 volt Shumacher since the early 70's since I still drove a stock 30 Model A PU around town and a 70 1/2 Z28 to work back then. Over the years that old charger has been on a lot of cars over night, and never fried any batteries I can recall. They usually last to within one month of the warranty:)
rattlesnake436
I have a craftsman 12v battery charger works great but it's branded sears works great
Sent from my SAMSUNG-SM-G890A using Tapatalk
nadogail
Coronado, CA
One of these days, but I won't say when, I want to build a charger from a small engine and an alternator, just like the systems at Epicenter.Com.
Should be able to do it for about $200. 80 to 100 amp output with regulation, using small engine, belt drive, alternator and a decent 12 volt battery. Scroungers can reduce this cost by using discarded lawn mower engines and junk yard parts.
My failure to start this project is because I have a lack of need and too many other half finished projects in my workshop.
KJINTF
Alaska
As others stated we need to know the application before we can supply good info
I have several "Converters" the things that are used in RV's ranging in power from 35 amps to over a 100amps. If you are looking for a bench power supply as well as a Battery Charger / maintainer then you might want to consider one of the Progressive Dynamics units that are both automatic and can be manually controlled. Lead acid batteries (FLA, AGM, Gell) are finicky to get properly charged and floated as needed when not in use for extended periods of time. Even more of a challenge are my new LiFePo4 batteries
