They are repairable. I have an old Sears 10A auto/manual. I replaced the auto/manual selector switch and the ammeter with inexpensive stuff from ebay and the carry handle with one of those renovable carry straps that come with car batteries. The joke is the original 15 Amp meter was junk and I got a pair of almost mint Simpson meters fot 8 bucks. They have a current new list of $90 so I even have a spare. The meter is worth more than the charger. I like your name. I had a Challenger T/A, the Dodge version of the AAR Cuda.I fix em! I have an old Christy battery charger that had some funky low tech reverse polarity protection circuitry in it that may have worked well back in 1990 but didnt work now. Even with schematics it didnt show me what they used for the Ballast light bulbs it used to load a transistor (I believe).
I tore out all that circuitry and just went straight from the transformer diode output to the cables nad so far its worked well.
If the fan quit and the charger stopped working. I think getting it working again would take more than fixing the fan. The semiconductors it was supposed to keep cool undoubtedly let out the magic smoke.Old ones are simple, transformer, bridge rectifier, misc wiring to go bad. Everybody should have one as the new units won't charge a totally dead battery. Mine is Western Auto.
Tons of the new smart style were returned as defective because the owners can't read, they won't charge a dead battery. Mine is Schumacher and still works great if not better than new models, but plenty of signs of wear and tear.
Many of the new ones depend on a fan for cooling, and fans go bad, but are easily replaced with long life ball bearing types.
BTW no reason for a good quality modern switchmode type to be large or heavy or expensive they are mostly PC power supplies with less circuitry.
Did some searches but didn’t come up with much. Does anybody make a decent 2/10/50 battery charger? All the shumacher,sears, century ones make it just out of warranty and then quit charging for me. Probably went through 5 over the last few years.
As its been said the newer ones with reverse polarity protection wont charge a dead battery...i know sounds stupid and it is.
Right you are. I forgot about thermal shut down. In that case I would expect it to work for a bit after it cools off. Those caps take a beating with switching power supplies running at 20khz or better. They use electrolitics made for that but they still fail.Yes and no, depends on the design and whether or not it senses temperature and shuts down or reduces power. With switch mode supplies what seems to fail are the capacitors most of the time and again depending on the design that might not kill it, just wound it. My fan has be flaky for years but it still puts out close to 20 amps even on a hot day, I have measured the 75 amp start mode, but that never seemed that practical anyway.
