Battery powered lawn mower
bornbadbob
My 20 yr old plug in electric lawn mower is on its last legs so I am in the market for a small (18”?) battery powered lawn mower. Very little yard to mow, maybe 300 sq ft. Wondering what brand is good, which to avoid? Any help will be appreciated.
Stuart in MN
Minneapolis
I know this is second hand knowledge, but my neighbor has had an Ego mower for several years and is happy with it. Having said that, for a lawn that small I'd stick with a corded mower...having to drag an extension cord is inconvenient, but you only have to put up with it for a few minutes and they're a lot less expensive.
For that matter, depending on the type of grass you have (they work best with short grass) a manual push style reel mower may work as well. There's no batteries or cords or anything to worry about.
pbon
We have a 40V Ryobi that we bought in 2020. Light, has a bag, works fine for our probably 600SF yard. Battery died this year, but I found a pair of aftermarket with thousands of reviews rating it as high as the original for less than the price of 1 original. One 6AH battery will cut the grass several times.
VT JD
Ontario, Canada
We have a Dewalt 20V and it has worked good for the last 3 years. Fits good with my other Dewalt 20V tools but if you don't use Dewalt then other brands are probably just as good for a small yard like you have.
WisJim
Menomonie, WI
We mow about that much and my wife uses our Green Works 40 volt string trimmer. It's too irregular to make an actual mower very practical. I agreed to move to town in part so I didn't have to mow anymore.
Fixr
SW VA
I would try to find one that uses batteries that you already have. With that small an area, you don't need the latest & most powerful. Or Ryobi has a small 18 volt one that's pretty inexpensive.
borgdog
Spokane, WA
I second this. I am pretty big into Makita 18V system, so I went with a Makita using the same batteries. I'm very happy with the mower, I think this is year 4 with it. Mine is larger and self propelled but I mow around 6000sqft, their smallest would work great for you.
bornbadbob
I am pretty heavily invested in Milwaukee. Hoping someone has something good to say about a Milwaukee mower. Generally the wife cuts the grass so I am hoping for something light and easy to manoeuvre
duneslider
Riverton, Utah
I also am a Makita user and have the makita 21" selfpropelled and really like it. I have a 1/2 acre lot, great mower for my needs. The makita trimmer is also great for my needs.
Metallitubby
ATL OTP North
Where are you located? I might be able to get you a pre-production Honda battery mower for testing if you are within a reasonable distance.
bornbadbob
Wife wants a mower, she doesn’t like the results with a trimmer but Thanks
pbon
I also have the Milwaukee mower. It is heavy duty and well built. Feels like it weighs at least twice as much as my Ryobi 40V, so for a small lawn the lighter Ryobi might be easier to use. Best with 12AH batteries for the run time, but try it with smaller if that is what you have.
Stuart in MN
Minneapolis
I suggested earlier you may want to get another corded mower, but if you already have Milwaukee tools stay with that brand. They sell their mower without batteries, so if you already have two of them on hand that's something you don't have to pay extra for.
bdbecker
Iowa
Unless something has changed, I would not recommend Ryobi 40V. I found one for free on a curb a few years ago and snagged it because it had a 6ah battery (I have a string trimmer and leaf blower on that platform). As I was poking around to see why it didn't work, I was less than impressed with the build quality and corners cut. I did get it running and ran it a few times around the yard, but for anything other than light duty use, I don't think it'll hold up in the long run.
Full story can be found here:
https://www.garagejournal.com/forum/threads/the-****-shack.332912/post-10272914
sh944
Linwood, KS
@Metallitubby If KC is doable for you, my wife and I are looking into one and she’d be happy to test for you. We mow a couple of acres but we need something small (ideally self propelled but we aren’t fussy) to get into a small fenced area and near landscaping around the house. Our Honda gas powered is nearing the end of its useful life and we will be replacing it soon.
My wife should have gotten a job as a John Deere test pilot, she’s been absolute hell on our riders.
finn
The UP, God's country
My BIL likes his EGO, and his machines aren’t well treated. Seems solid after a few years, and he likes the light weight on his steep yard.. I swear most of his yard is on a 45 degree slope.
My other BIL has one of those robot mowers, which he likes a lot….essentially no labor.
duneslider
Riverton, Utah
I’m considering a battery powered mower.
How do they perform on leaf mulching in the fall. I’m probably doing 6-8 weeks of mulching from late September to December every year.
I do not think that is currently the strong suit for any electric mower I have seen. Based on what you are doing I think you will not be happy with an electric mower.
sh944
Linwood, KS
I've done a couple of versions of robotic mowers (Robomow and Worx, primarily). For a smaller yard that is reasonably flat and obstruction free, they'd be the bomb. My problem is that I worked them waaaay past a realistic duty-cycle and they just couldn't keep up.
The Worx unit covered the small area that I am looking at getting an electric mower for (to replace my Honda self propelled, which by the way, has been a great mower imo) well enough, but its biggest problem is that it uses 5 razor blades attached to a hub for cutting. I know they do that because the weight of an actual mower blade would be too much for the motor/battery, but it just doesn't really cut all that well and the blades don't hold up very well. Battery life wasn't a problem as it was a small work area and it was pretty reliable as far as cycling, finding and docking in its station to recharge, etc. It just couldn't cut it, so to speak.
The Robomow units (I had two of them to try and maintain roughly 1.75 acres of mowing) had a decent mowing blade and were pretty reliable all in all, but my terrain was just too much for them and they were working themselves to death. I don't want to get into replacing $500 batteries on two mowers each year, and there were some other parts, including logic boards that I had to replace as well, and it just didn't have the "big manufacturer" support that I think these require. Robomow itself was fine and worked to be helpful supporting me while I was using them but I truly needed something that hadn't quite hit the marketplace yet. Husqvarna had a somewhat tempting unit hit the market after I had already committed to Robomow, but I don't think those were quite *there* yet either, so I am waiting for a generation or two of improvement before I jump back into robotic mowing, although I am a big fan of it.
Apologies to the OP, I will quit derailing your thread now. If anyone wants to talk robotic mowing, let me know and I'll start a separate thread.
4Kings
Southwest Missouri
For my OPE needs I have switched from gas to the AK series Stihl offerings. When the time comes I will be buying the Stihl mower. They offer a RMA 460 that's 19" that would fit your needs. I've got a blower, trimmer and a small chainsaw to clean up around the place. Been impressed with the power and longevity of the equipment and batteries.
pembol
I have had both the Makita dual battery mower (at a rental), and now an EGO 21" self propelled, and for me they have done an equivalent job to my prior Honda gas mower w.r.t leaf mulching. The EGO does have a specialized mulching double blade installed. The overall experience mowing with an electric is SOOOOO much better than a gas mower.
wolfhawk73
Eastern North Carolina
For a yard that small, I might look for the Quik Lok reciprocating trimmer attachment for the Milwaukee power head. It's cut should look much better than a string trimmer's, and it'll barely take up any space. Cheaper than the Milwaukee mower, for sure.
duneslider
Riverton, Utah
I haven't had issues cutting/chopping anything up with my makita but the suction with the electrics doesn't seem as good, and compared to like the snapper I had as a kid that thing would chew up and **** up leaves like it was nothing, I do not see that sort of performance with any electric mower I have used. I just don't think blade speed is as high. I have seen that makita makes a blade that is supposed to have better suction but I haven't tried it.
C.L S2000
LB, CA
yup! when my 25 year old gas mower went out 2 years ago i got the dual battery makita mower and its been working great!
y'sguy
Tulsa, Oklahoma
dunslider, yeah, I think you're correct about the lack of mulching and cutting with the electrics. I believe it also has to do with a lack of flywheel wheel weight. As in, there usually isn't any. But then if they did have the extra weight the batteries wouldn't last as long. It's a trade-off.
Skooterj
Indiana
I enjoy mowing. Got myself a new zero turn last year to mow my 1 acre lot in about 30 minutes. Usually do it twice a week when its growing because I like it and its quick. But I SO want a robotic mower for inside my fence. Cut off 1/8" every day, keeping it looking awesome and preventing weeds. Sign me up!!
CN Spots
NW Mississippi
I normally say to stick with the power source that you already have invested in (Milwaukee in your case) but their mower alone is pretty pricy. If 8 Franklins (mower only) is a drop in the bucket for you then I'd stay with Milwaukee. I don't own anything of theirs but I don't recall ever hearing anything negative about their cordless equipment other than the cost but that goes hand in hand with quality.
bornbadbob
I will likely get the Milwaukee but also eyeballing the Ego. Still undecided
Steve_P
As small as your yard is, anything even halfway decent will be fine. The top 6 rated mowers by Consumer Reports are 3 by Ryobi, Stihl, Ego, Kobalt. Makita was outside the top 10, FWIW. They didn't test Milwaukee for some reason. I've used a Kobalt at a friend's house, and it's fine, especially for your tiny yard. If you need it, also look at the trimmer and blowers and compare the total price.
They said the Ego LM2114 "mulched impressively" and under "cons" they said none.
bornbadbob
i have been eyeballing the Ego, another battery type won’t hurt, at least I would know my Milwaukee batteries would be charged, wife has a tendency to kill the batteries and not put them on charge after she’s done
