Battery powered screwdrivers
dandan111
Indiana
What are you guys using? Is the black and decker versa pack any good?
I think I would use something like this more than my makita 14.4 drill. My batteries are shot and I feel like trying something new. The dewalt screwdriver looks good also but for around the house maybe its overkill.
Ign
Butte Peak ND
I always keep a screwdriver in the house for quick stuff. I use the M12 'cause I've got a lot of it. The battery's been holding a full charge for 5+ months just sitting in the tool. The new Fuel driver is two speed, which I think is a great idea. Get some hex shank drill bits and you can drill too.
decaf
Stockholm, SWEDEN
I don´t like the impact drivers. They are too loud:shocking:
Soo i just bought the stongest drill driver i could find. Hitachi DS18DSDL.
It´s a torque monster(92Nm), with the 4.0Ah batteries.
I highly recommend it.
jjjrmx5
Cincinnati, OH
Having used the older B&D unit, I find them quite gimicky for the most part.
A good ratcheting screwdriver for most household jobs, and no battery pack to charge. A small screwgun or drill driver like the Bosch 12v max set or Milwaukee fuel 12 if you want something that can handle garage jobs and household jobs. For both drivers you'll be able to get replacement batteries for decades to come.
Battry powered screwdrivers failure seems to be is that they are really not geared to be used a lot or the jobs they work on can be limited. Thus the battery sits idle, eventually fails and more than likely is not meant to be replaced. Thus it's a disposable tool usually kept in the kitchen "junk dwr."
The current B&D's offer replaceable batteries but B&D is very good at pushing a tool and then bailing on it's customer support and parts supply chain for that tool.
If you do a LOT of household work, you'd be using a 12v or 18v drill/driver/impact in the first place, wouldn't ya?
No matter what ya buy, make sure replacement batteries are available. There is nothing worse and pocketbook foolish than having a perfectly good tool but no way to power and run it.
BTDT way too many times.
Good luck.
NY_treeguy
Hudson Valley, NY
I agree that they are more of a kitchen drawer tool, but I have a B&D that I keep around. It takes 4 AA batteries so the batteries are easily replaceable. It's handy for tedious long, low torque screws.
I still have my odl Black and Decker Versa Pack Screwdriver and for some things you can not beat it. ! It is great for running up/down small nuts with a hex-1/4" adapter like on appliances and lawnmowers and even driving some screws (probably nothing over a #8).
I bought my sun a DeWalt 1/4" hex impact driver and that thing is the cat's *** when it come to driving larger (#10 and #12) long (2"-4") screws in 2-by or decks. Make sure to get impact bits for it.
Buy a couple more Versa Pack batteries and keep that old driver, but get a new impact driver also.
D
dandan111
Indiana
Glade to hear you like the versa pack black and decker. It's the low end of the cost spectrum!
Low end, absolutely, but they fill a niche !
Someone bought me this set years ago. I thought it was a joke at the time, but it is amazing how many small jobs around the house I use it for. I keep them in the laundry room (with my wife's tools) so I don't have to run out to the garage !
byoungblood
Berryville, VA
I had one of those non-replaceable B&D electric screwdrivers that I used as a computer tech about 8-9 years ago. Company I worked for had a contract to replace the hard drives for the POS systems at virtually every Publix supermarket in the Atlanta area. It came in handy when I'd have to swap out a dozen or so drives at a single location and not wear out my wrist doing it.
After that one job, I don't think it got much use except for some occasional around the house stuff. Even then, I tended to use my regular screwdrivers more because it either didn't have enough torque, or was just too bulky to fit in places.
The Ratchet Man
Georgia
I have a Skil pistol grip style with the internal lithium battery. I picked it up in Bass Pro on clearance for $8.00. Why they had these I don't know but there were hundreds of them in the clearance section.
Normal price was around $30-$35 which would of caused me to keep walking but $8 was a steal. Its actually not to bad. It has power but I would consider the speed to be slow. I like the slow speed though so I can get a better feel of the torque I'm applying on delicate fasteners. It also has a led light. I've had it for about 6 years and it has done everything I've asked of it. They still make them although it comes with a carry bag now, instead of a plastic storage box with a clear lid that doubles as the charger.
http://mobile.walmart.com/m/phoenix;jsessionid=B105831E18B7568178480B6BCB04361A#ip/21863342?adid=22222222228000000000&veh=sem&wl6=19880599990&wl5=pla&wl2=m&wmlspartner=wlpa&wl1=g&wl4=&wl3=21486607510&wl0=
TangoFoxTrot
Once you own something like a Bosch driver, you'll see how worthless those old battery powered screwdrivers really are. They weigh about the same, so the only advantage I can see with a traditional battery screwdriver is cost.
The Bosch drivers aren't just for driving screws, you can adjust the power, I use it all the time just to remove and tighten screws.
It's probably the most used tool at my house.
SCscoutguy
South Carolina
Lowes has got the highly rated Hitachi 3.6v Lithium DB 3dl2 on sale for $49 (think I paid $59 for mine from Amazon).
Good little kit - comes with a case, charger and two batteries.
http://www.lowes.com/pd_60120-67702...earch=hitachi+db3dl2&productId=4176905&rpp=32
This is the exact tool I have had for 5+ years and I have used the living daylights out of it. I honestly don't know what I would do without it as I use it that much. The lithium ion batteries last forever on this little thing as well.
cburnscrx
Indianapolis
If youre truely looking for a cordless screwdriver, the B&D Li4000 is tough to beat. I have 2 of these and they're awesome. 3.6v lithium ion battery, clutch and 70in/lb of torque. Beats the Ryobi tek4 in that department. I hung my laundry room cabinets with it just to see if I could. Did great! Used it to switch over the brass door knobs to satin nickel. Did them all on one charge. I can't recommend it more!
http://www.amazon.com/gp/aw/d/B001GFINJ8/ref=mw_dp_mdsc?dsc=1
Holt
Bellevue, Nebraska
I use it for work and it will drive 2 1/2wood screws. 1/4 Quick chuck. I love it and it has a short lenght to get into tight spaces
cburnscrx
Indianapolis
Something to note when comparing the B&D Li4000 vs. the Hitachi and Tek4 is in-lbs of torque. Sure RPM's matter, but the torque is a big factor too. The Li4000 has 46% more torque than the Hitachi and 94% more torque than the Ryobi Tek4.
ddawg16
S. California
Why have a 'special' driver just for screws?
I have all of the Ryobi 18 cordless tools....the drills have a geared 2 speed selection in addition to the variable speed....and 1/2" chuck. I can chuck up a 1/4" extension and use the drill in low speed to drive lag bolts. The ***** paid for itself when I was putting in all the screws for my hold downs on the addition.
I'm using them now to drive drywall screws. Yesterday they helped me put up a wood gate.
cburnscrx
Indianapolis
I guess I just find a cordles screwdriver handy. They are great for little projects that don't require big tools. I use mine a lot. I have the DeWalt 18v impact, hammer drill, and drill, yet still use that little B&D all the time
cosmik binturong
.fr
don't forget the Panasonics: *click!* :thumbup:
they're tough little buggers that just keep on screwin' and unscrewin' for years then you get fresh batteries and here they go again! :D
atikovi
Suburban Washington DC
I do a lot of work on dashes and instrument clusters and the Versapak screwdriver is the best. The other pistol grip drivers cant get around or behind a steering wheel like the Versapak can. And if the battery runs out, pop in a recharged one. My charger does 4 at a time. I still have two 15 year old B&D gold batteries and are getting tired. Are the generic Ebay batteries any good?
Kracin
Omaha, NE
12v drill seems to work just fine as a nice screwdriver. two speeds, clutch, you can chuck up a quick disconnect bit if you want. it may be slightly longer than your typical screwdriver, but its just as light and functions just as well. maybe i'm crazy but i don't see a big need for a cordless screwdriver if you have a good compact drill?
George in Rancho Cordova
DANDAN111
I have a non-hinged Versapak screwdriver I got on clearance for $3.00. Very useful.
BTW
I remember seeing a Wheel Horse sign on US31 between South Bend and Niles in the 1950s. Can't remember if it was a dealer or the factory.
SquareLJ
I know this an old thread, but I love my M12 Milwaukee cordless screwdriver. $100, two batteries and a nice carrying case. Use it all the time now.
