Battery terminal brush
dodge610
North Canton Ohio
Who has the best battery terminal brush. I have a few of the metal ones with the screw off lids but they dont seem to last before the brush looks like someone ran over it. Would like to get one that is gonna last a while.:)
pipsters
USA
I have a Lisle one bought from Sears, seems to be holding up fine, as a plus it's US made. It's blue colored, plastic body with metal brush inside.
Fedwrench
Valley of the sun
bgott
Houston, TX.
Buy a few of the cheap ones at Harbor Freight when they are on sale for a buck. Seriously, they are a wear item and you'll go through even the expensive ones if you are using them much. I bought one of the fancy plastic ones off of the Snap-on truck for over $10 and ended up giving it back after one use, the post brush rotates in the plastic housing and they've been that way for years! The cleaner with the scrapers rather than the brushes work too well, they remove a lot of lead and make it harder to tighten the terminal down. They also don't work worth a **** on the sheel metal terminals a lot of the newer cars are using.
Vinko
Los Angeles
I got the Blue Point one like in the photo in the link above. It's the one on the far right. I guess they make a BP in blue and a Snappy in red. Anyway, it's Chinese - don't know if it's the best, but it works pretty well. But I like the question :) I'm always interested in finding what's the best in all tools, be it a humble terminal brush or the top-of-the-line. That said, unless I bought the entire kit, I probably wouldn't go SO for the brush itself. But the brush/scraper thing I got is good.
Toolhorder
Montana
The real question is why the corrosion in the first place. Most of the time if you need to be using a brush the battery is probably outgassing anyway and needs to be replaced.
