Battery Tester
Chadwilliam1
Cincinnati
I am looking for a quality battery tester to test mostly 12v but some 6v and some 12 v batteries cars and motorcycles mostly. I have a budget of 500 dollars. I was looking at the snap on EECS350. I couldn't find many reviews on it. I don't want to assume because it says snap on its a quality battery tester. I see EECS550A with a wireless screen but I am not sure how handy that will be. I have never owned my own battery tester I usually take them to get tested.
So what is the best battery tester in my price range?
Thanks
Sent from my SM-G975U using Tapatalk
Htscheg
Buffalo, NY
Midtronics is a great brand and a very usefull tool in the araenal!! I have one and its worked great for three years and still going strong!
zmotorsports
Northern Utah
I have a Midtronics tester at home and love it. I like the ability to test just a battery or the starting and/or charging systems together or separate.
I also purchased a nice carbon pile tester a few years ago that works great to test batteries under heavy load. I've found for RV's this works very well with the deep cycle batteries.
If you are a DIYer, put your money back in your pocket ! The only thing you need to do a proper test on a lead acid starting battery is a small bucket, water, baking soda, stiff brush, battery terminal brush, a decent battery charger and a good volt meter and some time and effort !
  • Clean the outside with water and backing soda and a brush. Repeat until there is no more foaming. Rinse well with fresh water.
  • Remove battery terminals and clean with tool.
  • Connect the charger. If the battery is low, it will take at least 12 hours to charge. Once charged, let it "rest" for about 30 minutes.
  • Check the voltage at the battery posts. write it down. It should be about 12.8V
  • Turn on your headlights. Check the voltage at the battery posts. It should only be down 0.2-0.5 volts. Leave the lights on for about 15 minutes.
  • Turn off your headlights. Check the voltage at the battery posts. Anything below 12.5V shows that the battery is getting old. Below 12.0V start shopping for a new battery !
IMHO, the BEST battery/alternator/starting system tester was the old Sun VAT 20/26/28. The 33 had a built in tach, but was really unnecessary. Finding one in good working condition is difficult.
Any battery tester that does NOT have a carbon pile load can not do a good test.
Showkey
"MEMBER EMERITUS"
Wausau WI
mrvm
PA
Interesting list of steps... on a questionable 4-5 yr old battery I should be able to skip a few steps and start with leaving the head lights on for 15 minutes after a full charge or long drive.....?
2ndGearRubber
Pittsburgh
My picoscope disagrees.
SMA shows it off. I can do an extended drop test and voltage drop all the connections at the same time if I like. Quick and easy, using the perfect load, the engine the system is designed to start. If one has access to a scope, you can do some pretty in depth battery and starting system tests. Like inspecting the contacts on the solenoid, grabbing relative compression while you're in there, etc.
I will agree, the capacitance testers can miss some major issues. Not that any customer would every replace a battery before it completely fails anyways. :lol:
