Battery tools for DIYers
Clearly a drill is the first tool on the list. I guess if you are only going to have one (or live in an apartment) you should probably get a 1/2" with hammer function (eventually you will have to drill concrete or brick).
What would be your 2nd, 3rd and 4th tools?
M635_Guy
NC
Impact driver would be way first over a full-on drill. When I was setting up my eldest spawn in the the first apartment earlier this year, I put a Milwaukee Surge in the kit - fantastic driver, and a decent drill for general use when needed.
I'm a homeowner for over 30 years total and don't have a hammer-drill (just a regular brushless 1/2" chuck - also Milwaukee)
dscheidt
No, a drill is far more useful to a not-terribly-serious DIYer. The clutch on the drill makes it far more useful for things like furniture asssembly, and it uses normal, cheap drill bits, not expensive, typically garbage quality, bits with a hex shank.
f121
UK
Impact driver. I often wonder how people built stuff before they were invented.
After that, it kinda depends what sort of diy they are doing etc. Probably a SDS, circular saw or jigsaw next, oscillating saw and sawzall are a long way down my list.
quickfarms
Southern California
It depends on what projects you are going to do.
I have three hammer drills
An impact driver, came in a kit
A 3/8” and a 1/2” impact
the impact driver is the least used tool of that group.
my choice would be
1, Hammer drill, they drill normally and also have the screw clutch
2, circular saw
3, this is where it starts to get specialized depending on use but here are a few that I use regularly, in random order
A, reciprocating saw, can trim trees with the right blade
B, 3/8” impact
C, 1/2” impact
D, blower
E, light
F, radio
G, jig saw
H, router
I, chain saw
J, die grinder for sharpening the chain sa
I very rarely use
The isolating tool or grinder
my biggest advice is to get a brand that has a lot of options. I just had this conversation with my nephew and we were discussing makita or Milwaukee. I prefer makita but I think it is just like ford or Chevy, Lincoln of Miller
RedneckWelder
The Ghetto Kingdom of Methlandia
I’ve come to hate a regular drill.
1/4” impact driver to me works far better these days. You can get DIY grade twist drills for them that work decently well especially for wood and plastic, masonary impact bits that out perform non SDS, traditional 1/2 chuck hammer drills, and regular bits. Socket adapters and nutdrivers for most smaller fasteners on cars and appliances. it’s a great all round tool.
M635_Guy
NC
A drill is, at best, a second-class driver of screws and other fasteners. Maybe you've got a **** impact driver or totally different experiences and use cases than me, but I have a nice brushless M18 Milwaukee drill that hasn't touched a fastener yet. My M12 Surge - bought the same week as the drill - has been absolutely fantastic and is probably my most-used tool. Mode 1 and 2 both have what amounts to the value/function of a clutch, and it's more automatic than the dial-a-clutch on drills. The Surge has been fine as a drill too :dunno: - Milwaukee's hex drill bits do a fine job when you have just the one tool, though I generally make sure I have the drill available for heavier/more intense jobs.
But the drill is a far less-used tool for me, mainly because I drill less holes than I did 15+ years ago, but also because the Surge does just fine in a lot of the light-duty drilling I face these days. I seem to assemble/disassemble a lot more stuff than I need to put holes in. I think that's probably true of most not-terribly-serious DIYers. If there's a choice for only one tool, I'm going with my Surge impact driver, and would definitely recommend it to just about everyone.
As far as the bits, if you've had garbage bits that's your fault. They're not that expensive. :rolleyes:
subroc
Dover, NH
A 3 speed hammer drill
A circular saw
Now I say that as what I find valuable as a first and second tool. The next guy might think a compact 2 speed followed by some yard tools are the way to go. Maybe another guy needs a drill, grinder and impact wrench as a good start.
Initially buy what you need. After that, buy what you want.
BTW, I have 5 drills including 2 hammer drills, 2 compact drills and an angle drill.
speed bump
Butte Montana
In 10 years of home ownership I can count on 1 hand the number of times I've needed something smaller than an SDS hammer drill at home (and not fill up the hands with the total times.
I would say impact driver. I plan on picking up a decent set of 1/4" shank bits so I almost never have to break out my drill when I do anything carpentry.
After that if you have landscaping to maintain a sawzall. Not as fast as a chainsaw but will eat grit and dirt all day long and just need more batteries and a $2 blade.
Finally one of those tire inflators.
fuggle
Way North in California
Well I am going to have to agree with M635. Ive owned many drills and still have a few. But since purchasing a 1/4” hex impact I almost never use a drill. I drill and assemble everything with the impact. Awesome tool. So awesome I own three so I dont have to change between bits. Lol
MushCreek
Upstate South Carolina
I'm a very active DIY'er. The 1/4" driver gets used the most by far. Second is the drill, followed by the circular saw and the Sawzall. I put everything together with Torx screws. Quick, easy, and can be disassembled.
GeoBruin
Piling on here but the impact driver is far and away my most used cordless tool. I don't have hex shank drill bits because I have a drill, but other than drilling holes, I can't think of when I would ever use a drill over an impact driver. Certainly not for fasteners.
Citation
Indy
Yeah, impact driver. I wish 90* impact drivers were more common. I had a Cman Nextec 90* impact driver. At the time I was just trying to get the drill that came with the kit (super deals when Sears was dumping the line). After using it a few times I was totally sold on impact drivers. What I didn't get at first was that, even thought the 90* setup isn't as nice to use vs traditional pistol grip when you have space, it's great when you don't. When I sold the Nextec impact driver for enough money to buy my current Ridgid 18V drill and impact driver I thought it was a clear upgrade. Well, yes when I was doing jobs that required driving lots of fasteners the Ridgid was better (the Nextec, while never too weak, was slower and had short battery life). But, when I needed to get that screw inside a cabinet... well I am sold on the 90* impact driver.
GeoBruin
The new Dewalt atomic impact is so short its almost a 90* impact.
Also, these work great for tight spaces.
DEWALT MAXFIT Right Angle Magnetic Attachment
SKU# 308436444
Citation
Indy
Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
SKU# 308436444
I have the adapter. Just not the same. The short body driver would address much of my concerns.
M635_Guy
NC
Oh good - now I don't feel so crazy for buying a second Surge...
brownbagg
i bought a makaita battery drill in around 95, its been on the shelf, never used once. I dont think the battery are any good now
trs71
How about a brand of tools? I vote Ridgid, mostly for the Lifetime Warranty-which the repair guy said, only about 20% of the people register it online, which is the one requirement. Milwaukee is quite a bit better quality, but $$$$ compared to Ridgid, How can you compare with lifetime battery replacement?
RedneckWelder
That’s if you can get them to honor it. I’ve heard of a lot of difficulty in registering and getting service on that, to the point where I’ll buy Ryobi (which has come up in the world a lot) over Rigid.
trs71
Ryobi is fine for a DIY-
But for HD, Why wouldn't they honor it? Especially if only 20% actually do the registration, which I easily believe is true, that's why rebates were a big thing. People here are generally lazy. It Seems risky for a big chain improvement store.
I've replaced battery packs, led lights, drills I got slightly wet (submerged my small Milwaukee drill in a tub that filled 1/2 with fluid, sat underwater for 2 days. I baked for 10 min 2x at 170 degrees, and didn't even have to charge the battery...)
I mean I can see if you're using a battery pack as a hammer. I've got a feeling it's a small % of people posting an issue, while 99% of returns go "unposted"- since they can't *****. :geek:
tarbellb
Oregon
Impact is a luxury
A chucked drill does everything a impact does plus holds twist bits which is indispensable
Impacting with hex shank bits is only for crude work, they wobble to much and you are limited to the standard sizes
1- chuck drill
2- circular saw
3- jig saw
now if you are like me you have 5 impact drivers (both M12+18) and 6 drills (again, M12+18)
Citation
Indy
Get a 3/8" ratchet and a 3/8" to 1/4" hex adapter.
It wouldn't address the part I was impressed with. The impact driver doesn't have counter torque and, more importantly, it can often free screws thanks to the impact drive profile. While a drill with similar torque might result in a cam out situation.
dscheidt
Impact is a luxury
Exactly. And the drill clutch is vastly superior for torque limited applications, like furniture assembly (I've seen so much stuff damaged from being assembled by impacts. yes, it can be down, and I'm sure you can do it. But it's a skill. ) It can also spin a paint stirrer. If I were to have only one, it's the drill, even though I use my impacts a lot more than my drills. (and i probably use the cordless screwdriver as much as I drill holes.)
Ronson25
1/4 impact driver and 1/2 drill are a must and possibally a saw of some kind
trs71
Id get a reg ratchet. The Milwaukees are nice, but if the 1/4 is smaller, id go the other way 1/4 ratchet 3/8 adapter. With larger tight bolts you'll have to break loose anyway, spin em off with a tiny 1/4.
A Skill was simply the best battery tool I've ever owned, it lasted 20 years. 100s of radiator shrouds.
M635_Guy
NC
Impact is a luxury
My impact driver holds drill bits just fine - lol
You say you have five impact drivers, but it doesn't sound like you actually use them. There are a massive range of hex bits, and they're far more precise than a drill with a chuck.
Riiight...
Get a worse tool for the infrequent drilling a casual homeowner does vs. installing fasteners... why?
I mean seriously - A drill is good at drilling and pretty **** at fasteners. An impact driver is great at fasteners and fine for light-to-moderate drilling tasks done by the casual DIY homeowner.
An impact driver is not a heavy-duty drill for sure, and not a hammer drill, but as a more-than-casual DIY guy, my Surge impact driver has done a lot of great work with more grace than the drill can manage. I have both tools handy, and no bias beyond what does the work the best. The drill sits a lot more than the impact. If I have to choose between my drill and my impact, there wouldn't be any hesitation to take the impact.
finn
The UP, God's country
Impact driver, with an assortment of drive bits and decent hex shank drill bits.
My wife has the little 12v Bosch, which does 90% of the tasks around the house. Stay away from the HF drill bits, though. Runout is so bad on some of them that they’re unusable. No problems with any other random brands she has.
Number two would be a cordless weed walker / trimmer for use around the property, and number three would be a cordless leaf blower for cleaning up the deck and patio.
Circular saws and sawsalls are way down the list, although the compact saws like the Milwaukee hacksall are useful, even though I hate my Milwaukee. Try a different brand, as most brands offer something equivalent.
Number five would be a cordless oscillating tool, Unless you’re doing construction, which most apartment dwellers and even homeowners these days don’t do.
The cordless drill would be next. A 3/8” chuck is adequate. If you have the driver, you will rarely use the drill, though, and most people would never need a hammer drill, or even a 1/2” chuck.
You really have to understand the demographics of the “customer”, though. I would guess that most tools are used for assembling toys and household goods, hanging pictures, stringing outdoor lights, and yard maintenance. Not many people doing remodeling, adding electrical circuits, building sheds, etc. those tasks obviously need things like saws, which I passed by.
wolf_from_wv
WV
1/2" drill
3/8" drill for smaller bits that seem to slip in the 1/2" chuck
Impact driver
reciprocating saw (works great for pruning limbs)
1/2" impact driver for automotive
circular saw
hedge clippers
soldering iron
jig saw
hammer drill
NUTTSGT
Northern Central Ohio
My impact driver never gets put away.
Blind1
I’ve built several nice pieces of furniture where I only used a drill/driver. Low torque needs are where the drill/driver comes in very handy. I prefer the smaller non-hammer styles.
For work where I just need to get some screws or lag screws into something. - the impact driver is the ticket. Fencing, quick box construction, rough woodwork, etc.
I like my Makita battery tools.
I prefer corded tools for any circular or recip type saws and other things.
seber
Deep East Tx.
Impact is a luxury
A drill will most definitely not do what an impact driver does. Impact drivers will drive a three inch screw into a deck without a thought and do it all day. A drill will simply twist them off. The impact will do that very quickly. It will also break stuck fasteners loose without breaking off the head. Unless you are using it a lot, I would just get a VSR corded drill for most DIYers.
M635_Guy
NC
In #1 mode (low torque) my Surge does a nice job of advancing the screw/whatever with just enough power, and doesn't over-drive or cam out. I have to admit the Craftsman C3 predecessor was mainly used for decking similar tasks and the drill had the rest of the driving tasks, but the Surge just took over everything.
