Beacon Morris/GG75 heater...do i need a wall thimble?
joelw23
I purchased the beacon morris heater and the concentric vent kit.
I'm going to vent this horizontally and through drywall/insulation/osb/vinyl siding
Do I need to install a wall thimble or is the 7" pipe on the concentric kit essentially the thimble?
if so, could i just install a large J-block in the siding and have the 7" pipe exit the garage through it?
The only thimble i've found that might work is http://www.menards.com/main/p-1444453722134-c-6894.htm?tid=-7164538749506288706
Thanks
diy96
Winnipeg, Mb.
Hi,
I just installed a SRP unit with a balanced or concentric flue. 2" flue runs inside the 4" fresh air intake. The 4" fresh air pipe was zero clearance through out.
J
joelw23
Sooooooo. I should be ok without a wall thimble?
thammel
Maryland
If you have a concentric system with the exhaust inside the intake then you won't need a wall thimble. This should be clear on the installation instructions.
Tom
J
joelw23
It's not clear in the instructions...
They say "install thimble if required by local codes or type of wall construction"
