Hello all-
I have access to a Harbor-Freight type of blast cabinet. I have used it over the years but not really impressed with its performance. I want to retro-fit it with a GREAT GUN. Any suggestions?
ALso, i have a 60-gallon compressor. Wondering if any of you have installed another air tank in-line to increase volume?
What media do you recommend for blasting primarily steel parts?
Thanks for your expertise!
Chris
You can improve on the HF blaster (and many others) by converting it to a bottom-feed "venturi" arrangement as opposed to the siphon type pickup tube:
If you have enough compressor, converting to one of these type guns, and running 1/2" hoses throughout, will get you some really awesome performance, as well:
Mike at Tacoma Company is a great guy, extremely knowledgeable and his stuff is priced very reasonably. He sells a kit specifically for upgrading the HF cabinets, because so many folks are in the same situation as you describe.
In my case, I was building my own blast cabinet and knew that I wanted to use this type of venturi arrangement. The last one I built when I lived in NY, circa 1988, used a siphon tube.
I also got my gloves, glove flanges, and gun from Mike:
I am using an abrasive blend of 50/50 crushed glass and garnet and find it works very well for typical paint prep/light rust removal. Mike mentioned that blasting pressures should be kept to between 50-60 PSI, higher than that just accelerates the breakdown of the media without much change in productivity.
Here is the cabinet I made, it is 30x30x48. The stand is 2" aluminum welded square tubing. Four 100W equivalent CFLs are in a box over the top located over an additional window.
Rather than use a foot pedal air valve, I used a 110V 1/2" NPT solenoid valve (5/8" internal ports) and a foot switch pedal.
Use clear film as already mentioned, to protect your viewing pane. I bought my film from Grainger, it is made for blast cabinets, is crystal clear, and is WAY cheaper than the stuff TIP sells (might be the same stuff).
Grainger item number is 3JT12
It is qty 20 precut sheets which are 12x24
It is made / sourced from blast cabinet manufacturer Econoline
$20.36 for 20 sheets, can't beat it....
Rob
