I had the same problem on the front tire of my compact Kubota tractor. I brought it to a tire dealer who determined the problem was due to a seal leak. They re-seated the tire on the rim and put in a new valve stem; it never fixed the problem.
I tried Slime and it never worked. They may have a different product that helps seal leaks. I ended up purchasing an inner tube and that fixed the problem.
I do not know what kind of vehicle you have but on the Kubota with a front end loader, the weight can cause the bead to come loose; I learned this after doing some research. However, I never had the problem with the other front tire so it is difficult to determine the root cause.
