texchappy
I need to torque some strut tower bolts down to 25 ft/lbs. I have a Craftsman 1/2" dr. 150 ft/lbs beam style torque wrench. Will it be accurate at the bottom part of the range?
If you're actively looking for cheap, then the HF torque wrench is the way to go. They're not the nicest wrenches but they're totally fine. I have one that's still accurate after something like 7 years.
Perform a search to find more. There are tons of threads about it.
Also, can you provide a link to the Neiko wrench? The same wrench sold at HF is sold under many other brands.
I wouldn't encourage you to buy a new torque wrench just to torque those strut bolts.
Really surprised that they were 1/2" and are being replaced by 9/16" with the mod I'm doing. It's for a MINI Cooper.
Generally accuracy for torque wrenches is 20%-100% of scale, or for your torque wrench, 30 ft-lbs to 150ft-lbs.
Like posted above, most clicker torque wrenches are only listed as accurate from 20-100% of scale. But I don't know if beam wrenches are also limited in that way. I actually don't remember reading anywhere that they are.
Your torque wrench isn't ideal, but it will probably be close enough for strut tower bolts.
I don't think the OP's referring to a "clicker".
If this is a deflection-type torque wrench, you should be OK.
That stated range of accuracy applies to clickers. There is no "20%-100%" limitation on the validity of Hooke's Law.
