Grain is correct in your first pic, incorrect in the 2nd. Flip the direction and you should be OK
Mostly agreed with this.
In the first pic, the grain running the length of the tines will keep the tines from breaking, but that grain direction will let the comb split between the tines.
In the second pic, the grain running across the tines will let the tines break off.
The first grain orientation is preferred, BUT if you want this to last, I would suggest that before you cut the tines, turn the comb so that the future tines will be facing up. Then make a cut on the tablesaw the length of the comb up the middle, about 2/3 of the way to the base of the tines. Then fill that cut in with a piece of wood called a spline that has the grain oriented the long way.
The splined comb will have the long grain supporting the teeth, and the spline will support the back of the comb.
