bearing separator
hoston23
godley, texas
i was using a Matco bearing separator at work on a axle hub, nothing else would budge it, well we bent it. i was wondering who makes a good bearing separator set. i have the small snapon CJ950, but after that the price gets outrageous
anyone have any thoughts
I WILL NOT BUY HARBOR FREIGHT:thumbup:
H
hoston23
godley, texas
i was looking at the big OTC set on amazon for like $350, but then i would have to buy the big OTC set with all the arms for another $350
Farmall 1066
Suburban Rockford, NE
I have a MAC, which I suspect may be same as yours...bent mine all to hell pressing a yoke off a PTO shaft.
In fairness, I had damn near 20 tons on it, and not much bite with the seperator. I think most any brand would have failed in this situation.
JJThrasher
Indiana
If you were pulling a Dodge hub they have a special puller tool that will pop the hub off on the truck for you works pretty good. OTC makes them.
search Ebay for "Owatonna" (aka OTC)
http://www.ebay.com/itm/Owatonna-To...934713?hash=item4d03b8f4b9:g:ZvMAAMXQWzNSm-ki
I think there's a small one on there right now made by Herbrand. yeah... been on there quite a while:
http://www.ebay.com/itm/VINTAGE-HER...:g:S0QAAOxyuPtRAnrQ&item=381728849821&vxp=mtr
Granco:
http://www.ebay.com/itm/Large-Beari...:g:NcoAAOSwaB5XoVa4&item=252486376286&vxp=mtr
(probably Army surplus)
OTC probably makes them for a mess of other companies.
Others: Cal-Van, CTA Tool.
GTA Matt
Zebulon, NC
The yukon bearing puller is hands down the best for pinion and carrier bearing removal. It ain't cheap, but its worth the money if you do a lot of diff work. For hub or pressed on axle bearings, a torch works best, spin rapidly with a good hot cherry on the inner race and it literally drops off.
Dagny
Northern Wi.
34 years ago I ordered one from S-K at the local hardware hank when it came it had OTC stamped on the back side its is top notch.
2oolhound
BC Canada
I had a big 8" OTC one that was stellar. There was a thread on here about a year ago that pointed out OTC is manufacturing in china now. Check coo and look for an old one. Mine was from the 70's - 80's. I have a snappy one now which looks and feels good but I haven't given it the use needed to praise it up yet. I like the fact the puller threaded holes in the splitter cheeks are offset and not 90' from centre. This allows you to get your hands inside the puller apparatus easier to remove axel nuts, bearing cages etc. or place spacers or guide the forcing screw.
rcupp
Curious as to why you wouldn't just torch it off if your replacing it anyway?
Nick the side of it and split it...
Finky198
North East
What exactly were you trying to do?
even before that step...
Did you try soaking the axle in penetrating fluid? preferably 50:50 ATF/acetone...
and :evil: IF it's that bad you should be pre-heating the race and then try pulling
Then comes the Above :beer:
WhiffySpark
Take pictures of what you're doing next time. I'm having a hard visualizing this but we can probably tell you a better way
