Bed frame **** joint techniques - HELP!
k p
Ontario, Canada
I'd like to start building a new bed frame, I'm upgrading mattress sizes and I'll need to build a new frame to fit. It will be a frame with slats (no boxspring) and I'l be working off of pictures I've found for inspiration.
In the past I've built frames with the headboard and footboard as their own solid units, they don't come apart. The only parts that disassemble are the side rails and the slats. This makes it very easy to take apart and move if necessary.
The last frame I built turned out great and I'm still using it without any issues, however, the screws that attach the rails to the headboard/footboard legs are visible from the outside. I'd like to improve on this with this next build.
Here's a few pictures of what I'd like to build...
I was thinking of using blocks inside the frame and using pocket holes to attach the rails but I feel that after taking the frame apart a few times it may weaken the joints.
Of course it goes without saying that the frame needs to be as strong as possible to stand up to the abuse that a bed receives.
If anyone has similar experience or a good resource to share please post.
astroracer
Mid_Michigan
I just upgraded an antique bed frame for the missus.
I used these. Very easy to use and they are VERY solid.
http://www.rockler.com/surface-mounted-keyhole-bed-rail-brackets
ry%3D400
Once these brackets a slipped together it makes for a very strong assembly. I was kind of surprised by how stout it is.
ry%3D400
All put together.
ry%3D400
ry%3D400
ry%3D400
Added some pictures of the finished product:
Zeke
I will add to the support (no pun) of using metal attachments. Too much movement on a bed frame (don't be thinking like that) sitting and tying your shoes and other side motions. Build it stout.
K
k p
Ontario, Canada
They make a few different options here. https://www.google.com/search?q=bed...7&sourceid=chrome&espv=210&es_sm=122&ie=UTF-8
The strongest joint that will last the longest if you take it apart is something like these, http://www.woodcraft.com/Product/20...g&matchtype=&gclid=CMfD7vv2t7wCFYkWMgodMAMAUQ
I have used the second ones in a previous build and wasn't comfortable with the amount of leverage these brackets had to withstand. I wasn't a big fan of the precision required to get these fitting correctly. Thanks for the links though!
Yep... lots of options like signcrafter says.
These are nice because they lock in place.
http://www.amazon.com/dp/B001DSZWN8/?tag=atomicindus08-20
That's another good choice, but similar to the ones mentioned above.
I like the look of those, they seem pretty solid. I'm a fan of the brackets attaching to the side of the wood too. Thanks!
Oh it'll be stout. I hate having stuff break when it shouldn't.
