Hey
Hope someone can give some insight here. I installed a 10k bedpak 2 post with wedge anchors 3/4. Instructions said raise posts and drill 4 inches. I called to confirm with bedpak if this is 4 inches with the plate or 4 inches concrete depth. The told me 4 inches including the plate which is 5/8th. So long story is I torqued everything down and admiring my work thought the anchors were quite high. Measured and yes all anchors only have 2 7/8 embedment in concrete. This was caused by the anchor lifting 1/2 ish inches to grab the wedge.
I need to remove these anchors and replace them anyone have any great ideas how to do this without destroying the concrete? Moving the lift to a diff location is sadly not an option in the small space. Cutting out the floor would be impossible as I have radiant heat. Slab is 6 inches, I drilled 3-3/8 following the instructions.
I am at a loss of how to fix this issue without making a royal mess. I don’t mind buying new anchors or upsizing.
