Beer Cooler Hinges
493mike
mid Michigan
My last post was the garden gate hinges I fabbed and here I am with more hinges!
Sitting at one of my favorite watering holes recently I remarked that it shouldn't be too difficult to fab a couple of hinges on one of the back-bar cooler doors. The owners daughter heard me and I volunteered, thinking 2 hinges.NO! She wanted all 12 hinges. So I agreed and took one broken hinge home. Well after about 2 weeks of puttering around I had them done and I installed them Monday morning-fit and worked great.
Plasma cut 1/4 steel for the movable leafs, drilled and bored the barrels, welded each barrel to the leaf, milled out the stationary half using aluminum 1 1/4" bar stock, coated the aluminum with Ever Brite and painted the steel.
I used iron oil lite bushings in the barrels and pins I purchased.
She needs latches too (I'm not volunteering).
Mike
493mike
mid Michigan
Thanks guys. The stationary half of the hinge is recessed below the overlaid cooler doors and all were deburred. I was reimbursed in cash (not really enough but I did volunteer).
Mike
Dutch01
Kempton Park, South Africa
Mike
I also found that these type of projects do not pay. One question though. You refer to iron oil lite bushing. I thought oil lite bushes were made from phosphor bronze :headscrat
larry4406
Northern Virginia
Mike
Not sure if machining is your gig for pay but maybe they could post a simple sign of gratitude with your info?
493mike
mid Michigan
I found the bushing at McMaster Carr. Both materials were available but the iron had a greater load capacity (think barmaids swinging on the doors).
Mike
Stuart in MN
Minneapolis
Mike
Are you saying every hinge on their cooler was broken? :confused:
FANTM58
Brighton, Co
Mike
FRANKLIN machine parts or something like that sells replacement parts for walk ins, also refrigeration parts warehouses.
I built these walk in coolers for 33 years...
493mike
mid Michigan
I took my wife to the bar Saturday for lunch (color tour quad ride) and the bar manager came out from the kitchen and saw my wife first and with a big smile asked what we were drinking. As soon as she saw me the smile disappeared. I think she's still pissed at me for charging $500.00 for the hinges. I doubt I made $5.00 per hour fabbing and spent 2 hours installing them, which wasn't part of the deal. Ya just can't win sometimes.
Mike
The Cobbler
many people don't realize the costs involved.
a buddy did some custom body work on a pc of **** basically for a friend of his. he had 60 or 70 hrs into labour, plus material, welding , trial fitting etc . he cleaned up some other stuff at the same time to make the whole job look better. He charged his buddy $1,000. about $15 per hr probably . A well respected body shop wouldn't have even touched the job , enver mind for a grand. It cost a so called friendship, because my buddy "ripped his buddy off" according to the talk at the bar.
king nero
Belgium
Why didn't you fully weld the leaf to the barrel?
I know it's without a doubt strong enough like this, but it doesn't "look right" to me.
Nice work though on the machined fixed parts of the hinges! For a voluntary project, it really does shine.
493mike
mid Michigan
I used some 3/32 7018 I had and quickly burned through the thinner wall I bored out to receive the bushing so I did the partial weld you noted (both sides).
Mike
SuperCat
Sacramento, CA
Your custom hinges are super heavy duty, great work! :thumbup:
Most people have no idea how much custom made hardware can cost. :sad:
NUTTSGT
Northern Central Ohio
They look good, print off the one that Marc linked and let them see how much hinges could have cost them.
I'll agree, some people have no idea how much time can be involved in something custom fabbed up. . . . yeah sure, you whipped it up in 10 minutes. . . . no clue.
Marctrees
TX/LA border - Toledo Bend
There are more "similar" hinges in the page set I linked...gotta go through the pages... all mixed styles. Widely priced differences between them, some down to $40 ea looking close to the 100$+ ones.
Gotta go through the pages.
Marc
rslaback
Westcentral Wisconsin
I'm sure they were taken aback at a price tag of $500 for the hinges. I doubt that is a price that a layperson would consider when someone says something "shouldn't be too hard."
Also, since this is a web forum and therefore I have to second guess everything, did you consider a set screw in the stationary portion to ensure that the pin doesn't rotate instead of the barrel? With those being made of aluminum and having a smaller surface area that the bearings (I hate that they call those bearings instead of bushings) my concern would be the pin rotating in the aluminum and wallowing out.
493mike
mid Michigan
Quite the price range! I think mine look better than the cheaper hinge. I charged $42.00 each so I believe I fairly priced the hinges even if I worked for less than minimum wage.
Mike
