Before I throw these small things away, what are they?
Ohio Andy
Columbus, Ohio
I intend to throw these in the trash but I want to know what they are. Which also means that if you consider them gold I will pay shipping to get them to you rather than pitch them. Curiosity overwhelms me.
Inherited stuff from (probably) a shop that fixed and wound electric motors. Either that or a tool and die maker. And that sums up my two grandfathers. The wide end has a round threaded hole. Picture below. The smaller item in the second picture is just a piece of steel with a hole in it.
Some of the rounded rods below (right) have hole in them. Some do not. Is that thing on the left a cutter for a lathe / mill (I do not know machining). And directly to the right of that, what is that hollow metal tube with a spiral cut in the side?
This has a tip like a flat screwdriver on the top, and the round looking shaft is really like a "tri-lobe" so three partial circles. Odd.
The largest piece of metal on the lower left has writing on it that I cannot really read even with a magnifier. My head hurts from trying.
The top line clearly states "THE WALTON CO". The lettering under that might say something like "PARTF382???" but it is mostly removed. And there is a 6 near the bottom. This is a hollow tube.
The round thing near the top is hollow and has a hole drilled through it. The little pieces of "wire" next to the Walton Co thing, well, no idea. I am guessing that the brass colored things are probably fasteners. The things on the right probably drop into something.
I have no idea but will watch for some feedback before I toss them.
Probably various armature and winding tools. I don't really use them anymore but will take them if you are junking them.
rsanter
visalia ca
Last picture on the right
There appears to be two collets
Please measure these as they may go to a die grinder and you may want or need them
If they are going to junk, I’ll take the stuff if nobody else is asking
O
Ohio Andy
Columbus, Ohio
Wow, that was fast. Oldtuleguy said he would take that stuff first so I will send it all his way after I figure out how to get an address. I think we can private message, I will see if I can figure out how to do that.
Tap Extractor stuff, interesting. I never would have guessed.
