Existing house wiring has me stumped! I did all my 3 way and 4 way switches in the garage with no problems. So I replaced some outdoor floods with LEDs. I noticed when they were off at night there was still a little light emanating from them, like a night light. How can this be I say? So I dig into it and find voltage (115ac) when the switches are off. Hmm. What's up? I pulled the two 3-way switches out of the boxes, left wires connected and checked and am really befuddled.
One box (#1) has power in and feed to the lights. The other box (#2) has just one 3 wire nm wire into it. The way things are wired seems really weird to me. Box #2 switch has black and white wires to the top 2 screws and the red wire (traveler) to the black bottom screw. This seems correct. However, in Box #1 it appears that power in feeds the black bottom screw and the black from box #2 feeds the top screw above the black bottom screw and the white from box #2 feeds the top screw on the other side. The red wire appears to be connected to the black feeding the lights.
What's weird is that this arrangement seemed to work fine with the older incandescent floods.
I knew something was weird when I was replacing the fixture holding the new led lights. I had the switches in the off position but in changing things the breaker popped. Now, I attributed this to the super sensitive combo arc fault/ground fault breaker. Guess not.
Any help is greatly appreciated!
Thanks,
Tom
Thanks,
Tom
