epoxonyourhouse
- Joined
- Jun 7, 2024
- Messages
- 10
Long-time lurker, first time poster. I've done a ton of searching and reading and could still use some beginner advice. I have a coated slab floor in basement (looks like concrete paint) that I want to grind off and do epoxy. Have to fix some cracks and divots too. I'm at the starting stage of doing moisture tests and I plan to rent a single-disc grinder and some sort of dust collection system from Sunbelt, and some sort of grinder for the corners the big grinder can't reach. Couple specific questions where I'm seeing conflicting info in my search results here:
Thanks for answering my ******* questions!
- Etching: A concrete contractor told me to grind, etch, then use a kit (e.g., Armor Proxy) of primer, epoxy and topcoat. However, many kit instructions (I've read quite a few now) say to grind, clean and then apply primer to the porous concrete, with no mention of etching. Do I need to etch after grinding, or just vacuum and clean after grinding? (And what do people like to clean with if I'm not etching?)
- PPE/ventilation: I'm way less concerned about my ability to do the job than I am about making beginner mistakes with my health. I have a 3M half-mask with P100s, will wear goggles and ear protection - might even just splurge and get a full-face respirator. However, I'm still freaked about the dust, especially with the mystery paint. Is the respirator and dust collection sufficient, or should I also use a fan out of a window and/or through the garage door? Do you use ducting with the fan? Is this overkill? Even reading on here, I'm not clear if setting up fans would actually make things better or worse. Ideally it would move any dust the collection system didn't catch outside, but I could also see it agitating air in the room and making it a dusty hellscape.
- Disposal: this is a pretty dumb question but I've never seen it done. How do you safely transfer concrete dust from dust collectors to bags for disposal? Just keep your respirator on, go outside and dump/shovel?
